Voltage jumping from 13v to 15v, Lights pulsing. HELP
Old May 26, 2022 | 11:07 AM
larys192's Avatar
Default Voltage jumping from 13v to 15v, Lights pulsing. HELP
Help. You can see from video how dashboard mileage light is pulsing. As well i have device showing current voltage it jumping from 13v to 15v all the time. Changed new alternator the same problem. Any ideas someone? maybe there is some voltage regulator witch i don't know?
Old May 26, 2022 | 02:47 PM
motorcarman's Avatar
Generator Suppression Module------Right Front, Engine Compartment
Old May 26, 2022 | 09:12 PM
M. Stojanovic's Avatar
There is no additional external voltage regulator, only the one inside the alternator. I had similar voltage fluctuation in two cases:
1. When I put in a lithium battery
2. When I tried using a supercapacitor in parallel with a normal led acid battery
The voltage fluctuation completely stopped when I reverted to using just a normal led acid battery.
Old May 26, 2022 | 10:39 PM
Vauxi's Avatar
Or just broken alternator.
Happened to me couple of times in my winter beaters.
Old May 27, 2022 | 03:16 AM
Other possible causes could be poor connections of the battery cables so I would make sure that all connections to the master fuses, as well as the connection of the ground strap to the body, are clean and sufficiently tight. Resistance developed inside the crimps of the main battery cables is also a known issue. The crimps may look very good on the outside but there may be some corrosion inside. Check if any of the battery cables is, after running the engine for say 5-10 min., is getting warm/hot.
RADas-
May 31, 2021 05:02 PM
jaguarxjordan
Jan 19, 2018 01:30 AM
JBGROSS
Nov 30, 2016 06:24 PM
Jandreu
Aug 20, 2016 06:04 PM
smgdata
May 19, 2014 06:08 PM
