Water pump o-ring?
Old Jan 31, 2011 | 11:38 PM
Dan R's Avatar
Default Water pump o-ring?
Just got a new Jag water pump for the 2000 XJ8.
It comes with a thin metal gasket.
It looks different from other, thicker gaskets on the internet with built in rubber seals.
The manual mentions renewing a pump o-ring.
Is this necessary for this version of the pump?
Thanks again,
Dan
Old Feb 1, 2011 | 05:19 AM
Sean B's Avatar
the metal gasket is correct, just make sure the mating surfaces are spotless, for added peace of mind a smear of hylomar or similar sealant could be used, we are talking a tiny amount here.
Old Feb 1, 2011 | 10:33 AM
Dan R's Avatar
Thanks. There is an ring indentation on the new metal gasket which I suppose takes the place of the old o-ring. I will use Permatex water pump gasket sealant for peace of mind.
Old Feb 1, 2011 | 02:05 PM
Dan R's Avatar
Bought some Hylomar this morning. Looks like the real McCoy.
Old Feb 1, 2011 | 02:13 PM
J.Bo's Avatar
Where did you order the Hylomar?
Old Mar 30, 2018 | 09:07 PM
Johnny_B's Avatar
Sorry about bringing an old thread back from the dead I figured it would be better if I just added my question on to this one, rather than start a new thread. When you (Sean B) say that a smear of sealant would be fine, what area are you referring to? Around the central portion, or around the central portion and the openings on each side? I ask, because the new water pump that I bought has a metal gasket, and no o-ring. I plan to go pick up some of the Permatex sealant tomorrow, so I can get my car put back together. But I want to make sure that I don't over-apply it, or put it somewhere where it shouldn't go. Thank you
Old Mar 31, 2018 | 07:51 AM
avern1's Avatar
You apply a very thin coating to the entire gasket mating face both sides of the gasket.
Old Mar 31, 2018 | 10:28 AM
Johnny_B's Avatar
Thank you
Wahooesprit
Dec 23, 2019 02:01 PM
Ozzy_UK
45
Feb 19, 2019 02:05 PM
Ozzy_UK
General Tech Help
Jan 14, 2016 02:52 PM
ksjaguar
Nov 3, 2015 10:14 AM
picard
Oct 12, 2015 11:56 AM
