Water Pump Revision
Old Apr 20, 2009 | 05:59 PM
nicknack's Avatar
Default Water Pump Revision
Can anyone tell me what years had the plastic water pump impeller? Did the factory correct the plastic impeller issue??
Old Apr 21, 2009 | 08:37 AM
JimmyL's Avatar
Default Water Pump upgrade
I have not been able to find definitive info on when the water pumps were changed
to have metal impellers, but I do know my 2001 had a plastic water pump impeller
before I replaced it. I think a 2002 would be safe, but no guaruntee. It's not a
difficult job to replace it though, especially if you're changing your coolant and
t-stat anyway.
Old Apr 21, 2009 | 08:48 AM
Brutal's Avatar
GEEZ I DONT THINK THERE ARE ANY EARLY WATER PUMPS STILL ALIVE WITH THIS PROBLEM ANY MORE. THEYRE STILL PLASTIC, BUT THE EARLY PROBLEM ONES WERE MOSTLY BLACK IMPELLER, NEW ARE WHITE. iM SURE THERES MORE INFO SOMEWHERE LIKE DATE CODING AS WE USED TO HAVE A BULLETIN FOR IT. BUT THAT WAS YEARS AGO LIKE 9
Old Apr 21, 2009 | 04:46 PM
nicknack's Avatar
Thanks for the info, just recently purchased my 03 XJ8 with 26K miles and wasn't sure if it was something I should replace right away.
Old Apr 21, 2009 | 08:52 PM
Brutal's Avatar
^^^^^no youre way past engine issues with that 1. Just keep the fluids changes, including the Filled for life trans(BS)
Old Apr 22, 2009 | 05:56 PM
nicknack's Avatar
When do you recommend a transmission fluid change/flush? I am planning on letting the dealer do that one... you agree?
Old Apr 22, 2009 | 06:39 PM
Brutal's Avatar
the problem with that is the cost of the fluid, it makes for a $500 flush. But is still needed, you may want to ask about coupons or research atlernatives. But a 26k I wouldnt even think about till 60k and Ide do a drain and check the fluid for smell and color, I f dark and smelly then flush, otherwise refill
Old Apr 23, 2009 | 02:03 PM
pjkbrit's Avatar
Autobox fluid service is not hard...buy filtre/gasket and Merc fluid on ebay...$70.00 for a kit and 4 quarts of OEM fluid for the 722.6 box...Merc part number is 001 989 21 03 10. I bought from ebay vendor ....current auction is # 230338156145....no affiliation.
I had to do plenty of research...but this is the right fluid...NO substitutes are permissible and if you use something else, or even another type of Merc fluid, you WILL risk tranny failure. Draining the box, dropping the pan etc swopped out almost exactly 4 quarts on my 02 XJR. I plan to do another fluid drop and replace at the next oil change...without dropping the pan, you'll drain about 3 quarts only...the drain plug is NOT right at the base of the pan...about 1 quart remains in the bottom. removal of the pan is messy and being clean is imperative.
Old Apr 23, 2009 | 04:31 PM
Brutal's Avatar
Now pj why dont you pm cadillac or jim and have them sticky this
Old May 11, 2009 | 05:54 PM
nicknack's Avatar
Hi Brutal,
Can you send me the procedure for a proper filter and fluid change? Any special requirements for re-filling?
Old May 11, 2009 | 10:53 PM
wazari's Avatar
Default trans fluid fill
Raise the vehicle for access.
Carefully remove the drain plug and drain the transmission fluid.
Refit the drain plug and tighten to the specified torque figure. (27nm) Use a new 0-ring.
INSTALLATION
Remove the fluid level / filler plug.
Using a syringe dedicated to transmission fluid only (not used for any other type of oil or fluids), inject transmission fluid until it overflows from the plug orifice. Fit, but do not tighten the plug.
Prepare PDU (at the base station).
Install the appropriate disk and switch ON.
Select the vehicle specification - ENTER.
From Engineering Tools select Toolbox - ENTER.
From Toolbox select Powertrain - ENTER.
Connect MPA and download cable to PDU and base station.
Select Data logger - ENTER.
Select Transmission - ENTER.
Disconnect download cable.
Connect MPA to PDU.
Connect PDU (at the vehicle).
Connect MPA cable to the vehicle diagnostic socket - ENTER.
Energize the vehicle ignition - ENTER.
From the menu select Transmission oil temperature (TOT) - ENTER.
Check that the fluid temperature is <30°C .
From above.
NOTE: Ensure that the TCM is connected and functioning correctly. Select Park and start the engine.
Cycle the gear selector.
From P to D.
From D to R.
From R to P.
From below.
Next adjust the transmission fluid level by the following steps:
Remove the filler / level plug. Inject fluid until it overflows from the plug orifice. CAUTION: The fluid temperature MUST NOT exceed 50°C . Wait for the flow of fluid to reduce to a trickle (for at least 1 minute).Refit the filler / level plug and tighten to the specified torque figure. (32nm) Check for leaks and remove spilt fluid.
Shut down and disconnect PDU.
Old May 12, 2009 | 10:01 AM
nicknack's Avatar
Thanks Wazari,
I was good until you got to the section that I am guessing requires a computer, what is a PDU and where do I get one?? Is it cost effective in purschasing computer vs just letting the dealer perform the task? Appreciate the time you took to write up the how-to guide.
Old May 12, 2009 | 10:44 AM
pjkbrit's Avatar
if you aren't a Jag technician and want to do this at home, my method worked out just fine.
Old May 12, 2009 | 10:54 AM
nicknack's Avatar
pjkbrit,
I would prefer to do this myself, what is your method? Do you have a link??
Old May 12, 2009 | 11:07 AM
wazari's Avatar
A PDU is Jaguar's portable diagnostic unit. A good scan tool that can measure trans oil temp via TCM will do. How cost effective it is depends on how often you're going to use it. I personally would get a PC based software program that supports CAN if I were going to buy a diagnostics tool. I think Autoenginuity's software is about $250 US.
A dealer performing the task is one solution. Having run a service dept at a dealership, the downfall is the cost of the fluid a Jag dealer will charge you. You can find the same Esso fluid at other sources for less money, including VW/Audi stores. If you can find a good independent Jag shop that will use the right fluid, that maybe another option.
Wahooesprit
Dec 23, 2019 02:01 PM
Ozzy_UK
45
Feb 19, 2019 02:05 PM
Ozzy_UK
General Tech Help
Jan 14, 2016 02:52 PM
ksjaguar
Nov 3, 2015 10:14 AM
picard
Oct 12, 2015 11:56 AM
