What are the 2 bottom buttons for?
Old Jun 15, 2025 | 06:38 AM
mikecampos59's Avatar
Default What are the 2 bottom buttons for?
2002 XJR...can someone explain to me what are the to bottom buttons for?
Old Jun 15, 2025 | 09:41 AM
Cafcpete's Avatar
The S button is for sport mode. This simply holds more revs before changing up, it does not change suspension settings. The one on the left is turn on the option for cruise control, which is then operated by the buttons on the right of the steeing wheel. They are odd in as much as as if they are down then they are turned off. They will light up in operation.
Old Jun 15, 2025 | 01:07 PM
motorcarman's Avatar
The sport mode button also changes the REVERSE gear ratio.(W5A580 has a two speed reverse gear ratio)
Old Jun 16, 2025 | 04:46 AM
markdpeter's Avatar
Well, you learn something new every day!
In my car the Sport button also means that you pull away in first gear rather than second - useful for when you want to show some pimply-faced youth in his noisy hot hatch what a big old (supercharged ) luxo-barge can do!
Old Jun 16, 2025 | 05:11 AM
eliotb's Avatar
I turn it on if I want to shower obstreperous back seat passengers with my hot coffee in the drink ejector built into the console lid. It works extremely well. It also works well in the X350 models with the four zone ac/heat option and the same ejector device. No need to ask how I know.
(I didn't know the XJR transmission had a second reverse ratio. Learn something every day!)
Old Jun 16, 2025 | 05:34 AM
Hooli's Avatar
Sport also changes the throttle response.
Sancho20
Apr 21, 2023 10:12 AM
tygerman49
Apr 25, 2022 01:31 PM
Sims
Mar 28, 2022 09:11 AM
tapau
Jun 26, 2021 07:45 AM
TylerDeBois
Mar 5, 2019 06:46 PM
