What is the coldest temperature you have EVER driven your XJ in?
Old Dec 17, 2009 | 08:32 PM
burmaz's Avatar
Default What is the coldest temperature you have EVER driven your XJ in?
For me its about 8 degrees. Super cold for me since I'm from Texas and I was driving out of state. My thermostat being stuck open did not help the heater at all.
Old Dec 17, 2009 | 09:20 PM
SteveM's Avatar
4 degrees F about an hour ago in western New York.
Old Dec 18, 2009 | 03:09 AM
chupacabra's Avatar
-14c works fine.. only takes time for antifreese to warm up, so it takes like 10 to 15 minutes for heater to start blowing warm air..
Old Dec 18, 2009 | 05:49 AM
Stu 1986's Avatar
I've seen the outside temp gauge say its been -8C, and deep snow all around. However, this seemed to affect my car very little and I was driving over a mountain road.
Old Dec 18, 2009 | 06:36 AM
ArmyJag's Avatar
-21 deg F with only one blower motor sorta working....
Old Apr 7, 2010 | 11:01 PM
Thomasso's Avatar
Living in western montana I've driven my Jags at -30 and even colder.
Old Apr 9, 2010 | 07:25 AM
steve11's Avatar
ud
+ 38 deg F in the SW USA. I was FREEZING and had the heater on full blast!
Old Apr 9, 2010 | 02:15 PM
burmaz's Avatar
How did they handle -30 degrees? I think the XJ was tested by Jaguar down to -40 degrees
Old Apr 10, 2010 | 10:41 AM
Thomasso's Avatar
They are pretty much the same as any other car in the cold. Although the traction control can be irritating when starting at intersections when slippery. It keeps braking the spinning wheel and slowing the starts. I shut it off to get moving faster. Would rather have positraction. Tom.
Old Jan 24, 2011 | 07:15 PM
1stXJ8's Avatar
Being up here in Canada, just this morning was -32 when i started the car
Old Jan 24, 2011 | 07:19 PM
yeldogt's Avatar
It was -2 F this morning when I pulled out.
Thats as cold as its been here in a very long time. She started right up !
Old Apr 9, 2011 | 11:09 AM
supraman's Avatar
wow, I live in calif., so I'm happy that all of you have seat warmers ;-)
45F is the coldest I've driven the car but glad to hear it handles much, much colder temps.
Old Apr 10, 2011 | 08:51 PM
Sinister 1's Avatar
Most of the vehicle programs I was part of tested to -40 degrees F. I would expect the XJ was also.
Personally I've run mine in -20 degrees F.
Today it was +80 Degrees F. I definitely prefer the warmer climates but am still stuck in Detroit.
Old Apr 10, 2011 | 09:27 PM
burmaz's Avatar
I have had my car in for 4 years in Texas heat and then 3 years in cold Boston. In Texas I drove in 105 degree weather and in Boston the coldest was about -6 deg F.
What I think were the casualities of these temperature extremes on a 11 year old car are: sagging headliner (repaired years ago), cracks in wood veneer, and possibly my 2nd set of valve cover gaskets failing prematurely (maybe?). My thermostat housing failed the same day I drove in -6 degree weather.
Old Apr 11, 2011 | 01:11 AM
plums's Avatar
Exclamation
Highly unlikely, otherwise owners and dealers in Canada would be howling right next to those in WI, MI, OH, IL, NH and upstate NY.
Old Apr 11, 2011 | 01:17 AM
burmaz's Avatar
I'm just thinking the rubber gaskets on my car may have gotten more brittle going from years of 100+ degrees and extreme humidity and direct sun to years of cold while my car is getting older at 11 yrs old. My car is parked outside all the time.
I do know the heat def made my headliner sag and the wood trim crack however.
Old Apr 11, 2011 | 01:57 AM
plums's Avatar
So, heat not cold.Maybe.But. headliner sags are also sometimes attributed to sunroof drainage problems.
Old Apr 11, 2011 | 03:17 AM
burmaz's Avatar
I can say the headliner sag was caused by heat with reasonable certainty b/c I had a very small bubble for months in the spring/winter, but within 2 days of record highs (20 degrees hotter), that bubble became the entire back seat section of the headliner. The heat def. made it worse BC the car was even parked the whole time in the sun. There was no rain, for it was a drought, hence the record highs.
LnrB
Oct 13, 2015 12:45 AM
hoodun
Oct 2, 2015 02:06 AM
workworkwork
Oct 1, 2015 01:44 AM
Gregory Neil O'Rear
Sep 29, 2015 09:52 AM
