What did you do to your X308 Today?
Old May 23, 2015 | 02:22 PM
  #1001
Daim's Avatar
Rusty got a facelift today... Yes, a lift! The bumper was hanging. Result: bumper doesn't hang anymore, but now I have "Rusty the Clown"
X300 grill and headlight panels and a stitched bumper
Before:
And replacement time:
Yes, I did a "Ghetto repair" on my bumper but heck, I'll be ordering a new one soon. I just needed it strapped for the TÜV soon
Old May 24, 2015 | 10:26 AM
  #1002
Daim's Avatar
Today I decided to change the door cards as mine were quite shabby.
Result: I was expecting some cheap and nasty OEM speakers... But no... Some owner upgraded to an Ampire and Eton system. That does explain though why it has some beat and bass... The rattle was from the broken door holders...
Luckily all the clips I needed were on the cards. I have about 10 spares now
Yeehaw!
Old May 31, 2015 | 01:29 AM
  #1003
ericjansen's Avatar
Default Foot-well lighting
Installed lighting in the foot-wells, something I think should have come standard on at least a VDP.
It comes on, and fades out just like the overhead courtesy lights (pic is not the best, the lighting is much more spread and softer, but it gives an idea).
Old Jun 1, 2015 | 05:21 PM
  #1004
Lyndon1116's Avatar
Eric
Was that using the standard wiring, or did you have to run wires for it?
Looks good, would like to do the same thing.
Or is there a thread on that here somewhere?
Lyndon
(Cold Sydney)
Edit: I found the thread you started in this Forum - all good. Did you buy particular light fittings, or just a bulb?
Old Jun 2, 2015 | 07:46 AM
  #1005
bdboyle's Avatar
Originally Posted by Lyndon1116
Eric
Lyndon
(Cold Sydney)
You can pick up a couple of map lights from Victoria British that were used in the MGB; they're not Jag parts necessarily, but, mounting them with the lens facing into the footwell on the closure panels under the dash, wiring them up, would work:
#9 should work, and 1) is not that $$$, and 2) is a normal british fittment
YMMV; I kind of like using a heritage part in these cars...LOL.
Old Jun 2, 2015 | 05:55 PM
  #1006
ericjansen's Avatar
Eric
Lyndon
(Cold Sydney)
As already mentioned by bdboyle, any kind of map lighting will do.
I used some left-over well lights from my Grand Cherokee, I think they are 9W.
I also read somewhere to use the rectangular x308 boot-lights (which I consider to use for the rear, and recess in the fuse covers).
Eric
Old Jun 3, 2015 | 05:56 PM
  #1007
VR6Guru's Avatar
Put in new front Bilsteins, changed the bushings on the shock tower, put in new sway bar end links.
No more clunking while driving. It rides nice and smooth
Old Jun 4, 2015 | 01:20 PM
  #1008
Daim's Avatar
Sandblasted and painted my front brake calipers today. New seals are sitting here wait Ing for installation
Old Jun 5, 2015 | 04:08 PM
  #1009
Daim's Avatar
Fitted the new seals and rubbers on the calipers... Now ready for installation...
Old Jun 5, 2015 | 07:56 PM
  #1010
bdboyle's Avatar
Default Nothing for me today
Too busy with doing the spa treatment on the XF...but...I do pick up the XJ8 from the body shop tomorrow after the wheel arch rust repair, bumper repray/rectification, rear window removal and channel rust repair, and headliner replacement.
Oh, yeah, and buffing the body out. Still have some dings that need be rectified (PDR time), but, the big cat should be home tomorrow. Photos to follow.
Old Jun 6, 2015 | 10:04 AM
  #1011
Daim's Avatar
Very busy lately... Started off that my front left brake didn't work. So I had to replace that caliper. But I thought why do one if you can do two instead? So both front calipers were replaced by some from my old XJ6 (some of the few parts what are the same). Sandblast, respray, rebuild, refit
So, I started with rusty calipers and blasted them to look like this:
After rebuilding both calipers, I changed both... Especially because the front left wouldn't work
And after that was done, bleeding, and brake testing, it worked out to be perfectly sorted. I can now finally stop properly
And while I was at it, I replaced the exhaust tailpipes...
Old Jun 7, 2015 | 12:38 AM
  #1012
GGabriel's Avatar
I use ebay. I've picked up several sets (xenon blubs/power box/wiring) over the years, all for $40 or less. If the bulbs don't fit perfectly, just sand down the plastic ring surrounding the bulb until they do. It's an incredible difference. They are all plug in. Very easy to figure out.
Originally Posted by Tirefriar
Hey,
Dinger. I want to do the same. Can you give me the particulars for each application that you have done? I looked through several threads but those were just general with no specific part descriptions. Thanx
Old Jun 9, 2015 | 04:00 PM
  #1013
casualcat's Avatar
Drove it today!
Old Jun 10, 2015 | 06:31 AM
  #1014
Richy_Jsy's Avatar
Got her back from body repairer yesterday, took her for a drive. Great. Need to get electrics looked at as several things wrong there. Was in hospital for 2 weeks after the accident and door was wide open and although plastic sheeting was placed over the door hole, the door itself was open to the weather, and probably got soaked on rainy days. Drives brilliantly though. So good to have her back.
Old Jun 10, 2015 | 08:51 AM
  #1015
80sRule's Avatar
Yesterday I did:
Outer tie rod ends
RF inner tie rod
RF wheel bearing
RF lower ball joint
Today I'll finish putting it all back together and drop it off to get aligned tomorrow!
Old Jun 10, 2015 | 07:46 PM
  #1016
D. Fite's Avatar
Washed it.
Old Jun 11, 2015 | 12:22 PM
  #1017
Daim's Avatar
Made my original leaper a little different than the rest and took it for a spray...
Old Jun 11, 2015 | 01:13 PM
  #1018
CharlzO's Avatar
what, no details? Just leaving us hangin?
Old Jun 11, 2015 | 01:19 PM
  #1019
Vector's Avatar
I introduced the cat to her new stable mate.
Vector
Old Jun 11, 2015 | 03:09 PM
  #1020
Daim's Avatar
It is a start to my "get rid of the chrome" plan
How can I put it without giving it away... Hmm... Lets say, the chrome will stay chrome but beneath a layer of other colours(!)...
More when the test object is ready
