What is the difference if any
Old Oct 11, 2019 | 12:28 PM
Nicdilla's Avatar
Default What is the difference if any
Between the 2001 Jaguar xj and xjr throttle position sensor?
Old Oct 12, 2019 | 09:38 AM
Mvirgil's Avatar
Fairly positive they are the same, both models use the same throttle body assembly.
Old Oct 17, 2019 | 05:25 PM
Nicdilla's Avatar
Default Thanks for the input!
I appreciate the feedback. There is so little info on the TPS out there.
Old Oct 18, 2019 | 06:11 PM
motorcarman's Avatar
Jaguar throttles are sold as an assembly!!!
People do replace the TPS but you are on your own to set it up and get it set correctly.
The ONLY difference between the AJ27 NA and SC is the 'air assisted injector' valve on the throttle.
The NA uses a valve and the SC uses a 'blanking-plate'.(they can be swapped)
bob
alfaholic
Jan 13, 2024 06:58 AM
fredd60
Mar 10, 2019 09:01 PM
al_roethlisberger
Jan 11, 2016 01:17 PM
nairnman
Dec 20, 2010 08:53 AM
