What else can be fixed as long as the car is already halfway taken apart?
Old Mar 23, 2012 | 03:58 PM
chernobee's Avatar
Default What else can be fixed as long as the car is already halfway taken apart?
Hello what is the real name for the timing chain cover gasket? Also my 03 XJ8 will be having the valve cover gaskets, spark plugs, timing chain cover gasket, transmission fluid and filter, oil pan gasket, drain plug, engine oil filter, and transmission filter & fluid replaced and I am wondering what else can or should be done while it's already opened up? Its a great car that just needs a little tlc. The last owner didnt do a lot of routine services and id hate to overlook something. We have already replaced the water pump and a couple of hoses. It has 145k miles. Thank you---mike
Old Mar 24, 2012 | 04:49 AM
Sean B's Avatar
replace the plastic thermostat tower with an upgraded metal version along with a new thermostat?
Old Mar 24, 2012 | 12:38 PM
chernobee's Avatar
thats a good one thank you! ill check and see if that was done on the last visit to the mechanic shop
danpop
Sep 3, 2015 08:06 PM
gene1
Sep 3, 2015 08:04 PM
SingBlueSilver
Aug 27, 2015 02:20 PM
dpappyp
Aug 27, 2015 06:31 AM
Robgodius
Aug 25, 2015 09:34 PM
