what Module stores the trouble codes
Old Feb 3, 2015 | 11:05 PM
dave308's Avatar
Default what Module stores the trouble codes
Header says it all 99 XJ8 , cant clear codes , curious what module stores them , Thank You
Old Feb 4, 2015 | 02:25 AM
JagV8's Avatar
Depends on the code e.g. ABS codes will be in ABS module and so on. The only codes a typical tool can read are in the PCM and the tool can clear them. Of course the fault may still be there and can immediately re-flag so may look like the tool failed. Fix the fault....
The OBD idea is that you always carry out a fix before a clear. Codes self-clear when fault fixed so strictly you don't need to clear the code.
Steviedee1st
Nov 28, 2023 06:32 PM
Jpav27
Jul 31, 2022 06:43 AM
Chuck Schexnayder
Sep 18, 2015 03:10 PM
jagfool
Sep 14, 2015 07:50 PM
tonyforman
Sep 10, 2015 07:23 PM
