Wheel compatability... Will X350 wheels fit on our X308's ?
Old Sep 1, 2019 | 07:49 PM
Indy-Guy's Avatar
Default Wheel compatability... Will X350 wheels fit on our X308's ?
I'm looking for a spare set of wheels to mount some drag tires on for my 2001 XJR.
As the title suggests, Will the wheels from a newer Jag fit ? If not, are there any other OEM wheels from a different manufacturer that will fit?
  • I'm looking for a low budget solution here..
Old Sep 1, 2019 | 08:09 PM
motorcarman's Avatar
NO
Old Sep 1, 2019 | 09:22 PM
nilanium's Avatar
Nope, there's some aftermarket solutions out there but nothing OEM from non-jag.
Or you could buy mine https://www.jaguarforums.com/forum/market/222090
Old Sep 3, 2019 | 09:39 AM
Count Iblis's Avatar
Use Corvette wheels. Offset may be wrong but the old school 5 stud GM pattern lines up to the Jag.
The BMW pattern is almost line on- but slightly out (by 0.65mm) - and some have had studs break as a result.
Old Sep 3, 2019 | 02:42 PM
yeldogt's Avatar
They wheels for an XK8 of the same period will fit ... I use a set for my snows
Old Sep 3, 2019 | 09:48 PM
M. Stojanovic's Avatar
According to this website (https://www.wheel-size.com/size/chev...corvette/1984/), 1984-88 Corvette wheels had good offset (30 mm) for the Jag but the wheels are 16 in. Later Corvettes had 17 in. wheels but too large offset, 50+ mm. Then, from 2006, there were Corvette wheels with 40 mm offset which would sit 7 mm inwards compared to the factory Jag wheels. So, the 50+ offset wheels could be used on the Jag with 20 mm spacers or the 40 mm offset ones with 10 mm spacers.
Old Sep 6, 2019 | 02:20 PM
vincent661983's Avatar
nothing is impossible, but I can tell you it wont be a direct plug and play. why I know that( I trust me that I know that the best,haha) , because I was able to put a set a Centa Chrome wheels on our X308. search my old thread to see how I did it through out the process and problems I had faced.
it is complicated but achievable
chillyphilly
May 14, 2018 08:16 AM
Mashjag
Nov 1, 2017 07:05 AM
Mustang1967
Jun 3, 2016 05:24 AM
Pumpkinate
Jun 23, 2015 05:39 PM
MaximA
Feb 6, 2014 09:43 AM
