Wheel lug size
Old Mar 30, 2011 | 07:56 PM
ant17's Avatar
Default Wheel lug size
I have a 2003 VDP and was wondering what the correct size is for wheel lug nuts?
A 7/8 socket fits it, but something tells me its metric and not 7/8's.
TIA
Old Mar 30, 2011 | 07:58 PM
test point's Avatar
I believe that it is 7/8". There is a very strange mixture of SAE and Metric on the car.
Old Mar 30, 2011 | 09:23 PM
motorcarman's Avatar
7/8ths and 22mm are almost EXACTLY the same
bob gauff
Old Mar 30, 2011 | 09:27 PM
plums's Avatar
While on the subject .. does anyone care to discuss the sizing in relation to alternative replacements?
The thread is 1/2-20 and is easy enough to find.
The question is the diameter and length of the shank.
In particular, the clearance between the diameter of the shank and the diameter of the corresponding hole in the wheel.
While the wheel is supposed to be hub-centric according to reports here, it is still worrisome to think about too much clearance between the shank and the hole.
Are there good lug nuts that people have found with a close fitting shank?
Measuring a stock one:
0.7020" or 17.92mm at the fat part of the shank that retains the washer and a length of 0.55' or 14mm.
Old Mar 31, 2011 | 05:40 AM
ant17's Avatar
Thanks all, ok..
cheers
Old Jan 20, 2014 | 05:50 PM
XJRChad's Avatar
I tried taking my lug nuts off with a deep well 7/8" socket. It wouldn't fit, so I knocked the socket on with a hammer. Long story short, I have one lug nut off, but it is now stuck in the socket. I really hope these cheap tin-covered lug nuts are aftermarket, or Jaguar has some 'splaining to do...
MrWest
Dec 1, 2015 09:18 PM
Gerard Radimaker
Sep 13, 2015 10:33 AM
metalmarty
Sep 11, 2015 07:05 AM
iownme
Sep 11, 2015 02:57 AM
ferraripete
Sep 10, 2015 01:24 AM
