Wheel Question!
Old Apr 23, 2020 | 07:44 PM
Vegas_Jag's Avatar
Default Wheel Question!
Hello all, got a question about wheels for my xjr.
im looking to buy a set of 18x8.5/18x9.5 30/35et.
Buying a set 5x120 bmw wheels, and found a shop that can machine them to 74.1 to fit my car.
Does this sound right?
Old Apr 23, 2020 | 10:35 PM
M. Stojanovic's Avatar
If your car is X308, you could use BMW wheels but with quite a bit of modifications:
1. The centre bore has to be machined to 73.8 mm (not 74.1 as you mentioned)
2. The Jag PCD is 5 x 120.65 so you will also have to have the bolt holes and their tapers machined to this PCD (from BMW's 5 x 120.00).
See the attached write-up by somebody who has adapted BMW wheels.
File Type: pdf
Old Apr 23, 2020 | 10:52 PM
Vegas_Jag's Avatar
Thank you!
Old Apr 25, 2020 | 01:22 PM
Vegas_Jag's Avatar
Are the offsets correct?
I saw a set of Conventry wheels with a 20et offset?
Old Apr 26, 2020 | 01:29 AM
The factory offset is 33 mm so the BMW wheels you mentioned (30 mm front) will be fine but will be sitting 10 mm out compared to stock 8 in. wide rims. As for the rears, 35 mm is also ok but at 9.5 in. the tyres will be sitting 3/4 in. out compared to stock so check for clearance to the wheel arches.
yardbird
Jan 28, 2017 08:40 AM
JimC64
Feb 5, 2016 07:36 AM
pezzonovante88
Aug 7, 2014 12:24 PM
chknhwk
May 26, 2010 02:48 PM
