When to replace crank position sensor?
Old Dec 5, 2023 | 03:27 AM
ForTheLoveOfCars's Avatar
Default When to replace crank position sensor?
How long do the crank position sensors usually last on these cars? Any signs it may be failing?
(not a current issue but to stay ahead of all the parts)
Old Dec 5, 2023 | 04:18 AM
Addicted2boost's Avatar
They seldom give any issues unless there’s a lot of corrosion under the car. In that scenario I've seen the sensor corrode in place and they have to be destroyed in order to replace one. For example, if you’re trying to pin the flex plate to put the engine in time, the crank sensor has to be removed.
Old Dec 5, 2023 | 05:28 AM
could you expand on what you mean by “pin the flex plate?”
i might know what you mean but to be sure
Old Dec 5, 2023 | 07:02 AM
Quadcammer's Avatar
To lock it with a tool when doing timing work.
Replace it when there is an issue or code. It's an easy and quick replacement so no real point in preventative maintenance here.
Old Dec 5, 2023 | 10:02 AM
thank you i will bare that in mind for future reference 👍👌
dcjag22
Oct 4, 2022 06:47 AM
Kopi
Feb 24, 2022 04:31 AM
stevepaa
Oct 28, 2021 08:28 AM
Qvhk
May 9, 2016 06:05 AM
lamoz
Dec 8, 2010 09:08 PM
