will a 2003 3.9 ls v8 work in my 99 xjr.4.0
Old Aug 17, 2014 | 11:17 AM
ls1swap's Avatar
Default will a 2003 3.9 ls v8 work in my 99 xjr.4.0
just got a seized 4.0 xjr8l. I am looking for a replacement engine. I found a salvage 2003 Lincoln ls with a 3.9. what issues does the variable timing present? can I just not use it and use the 4.0 intake and ecm?
thanks in advance
Old Aug 17, 2014 | 11:31 AM
motorcarman's Avatar
People put CHEVY engines in Jaguars.
People put Aircraft Engines in cars.
With enough time and money, most anything is possible.
I don't know what car you have? (xjr8l) Is it XJ8 or XJR? Is it a Long Wheelbase?
I would just find a compatible AJ26 or AJ27 (you did not specify a MY) and install it.
There are thousands of good used engines in salvage yards across the land.
Why complicate your life with unnecessary work and redesign.
The 2 engines are SIMILAR but not the same.
bob gauff
Old Aug 17, 2014 | 12:36 PM
ls1swap's Avatar
my bad on the name it is a 99 xj8l which I believe has a aj27 in it. I don't see many lower mile 4.0 engines at a decent price. that is why I am looking at the 2003 3.9. ls v8. I know anything can be done with time and money I put a 5.7 ls1 v8 in a fiero once. I don't want to go through that much work I am looking for a bolt in with few mod if necessary.
Old Aug 17, 2014 | 01:34 PM
test point's Avatar
Long block would probably come close with parts swap. There have been discussions on this subject.
Old Aug 17, 2014 | 07:04 PM
ANY 4.0 AJ27 normally aspirated from 1999-2003 X308 or 1999-2002 X100 will bolt in without modification.
Even the later engines (2002-2003 4.0 liter) with 'silent-running-chains' are bolt-in ready. All the sensors are compatible.
You can 'adapt' the AJ26 to operate correctly with some modification.
bob gauff
duecedriver
Dec 25, 2015 11:47 AM
3jagfamily
Oct 1, 2015 01:49 AM
dieseldoc
Sep 28, 2015 01:17 PM
kabs3012
Sep 12, 2015 10:40 AM
kabs3012
US Midwest
Sep 10, 2015 01:17 PM
