Will Stereo Work?
Old Jan 11, 2019 | 11:30 PM
omgimali's Avatar
Default Will Stereo Work?
Amazon Amazon
will this apple car play pioneer work with our x308? i'm wondering wiring and fitment wise.
Old Jan 12, 2019 | 07:28 AM
CharlzO's Avatar
Fitment will, since it's a shallow depth. You'll have to modify an aftermarket faceplate opening to take the double din. Wiring will be another story though, as they don't have a plug-n-play wiring harness. So it'll depend on which model X308 you have with or without premium sound, and the like, but plan on pretty much wiring each speaker directly
Old Jan 12, 2019 | 05:16 PM
King Charles's Avatar
Yes they all pretty much "fit" it depends on how much modification & work one wants to do lol.
Old Jan 13, 2019 | 02:12 AM
anduha's Avatar
Does it wire directly to the speakers or connect to an existing head unit via USB or another adapter? I doubt this will connect to the stock head unit and even if it did the sound would be junk by today's standards.
If your Jaguar has the standard sound system (no subwoofer on the rear shelf) then the speaker wires run directly to the dash head unit so easy conversion to aftermarket. If you have the premium sound system then the speaker wires terminate at the amp above the CD changer in the trunk which is great if you want to install an aftermarket amp and run RCA cables to the dash. A pain if you just want a dash unit as you will need to run wires back to the head unit from the trunk.
I know there is a great single DIN adapter kit out there that looks great and comes with wiring diagrams for both the premium and standard sound systems. I have installed three with little headache.
Bader
Nov 5, 2018 09:56 AM
William James
Aug 19, 2016 04:15 PM
phd12volt
Audio/Visual Electronics
19
Mar 13, 2016 08:32 PM
nkdarn
Jun 15, 2010 10:45 PM
