Window and Sunroof Module Reset - Driver's Window Won't Roll Down/Sunroof Won't Open
Old Aug 28, 2017 | 02:04 AM
nd4spdlsc's Avatar
Default Window and Sunroof Module Reset - Driver's Window Won't Roll Down/Sunroof Won't Open
I've done reading across a few different posts and I cannot find a definitive solution. What is causing the module to be reset (power loss at some point) where the driver's window won't go down and the sunroof won't stay open? Multiple hard resets only lasts for so long. The battery is pretty new in the car. The battery is not getting drained when parked as the car will start after sitting for long periods over multiple weeks without issue. I'm going to replace the fuse just to ensure there isn't something suspect, but are control module failures common? Can they be fixed if you have some electronics experience?
Old Aug 29, 2017 | 07:25 AM
jrb53's Avatar
Default hard reset
try another hard reset hold negative cable to positive for at least 15 seconds this seems to reset everything. I only used to hold it for 5 seconds then would have to do it again after a month or so worth a try jrb53
Old May 19, 2018 | 10:27 PM
SannaT's Avatar
I had a similar problem with the driver's door of my car, turned out the latch needed to be replaced
Old Mar 14, 2019 | 08:08 PM
nd4spdlsc's Avatar
Is this the latch mating to the B pillar?
Old Nov 25, 2019 | 09:54 AM
pwayko's Avatar
Where can I learn how to reset the module
Old Nov 25, 2019 | 10:10 AM
Carnival Kid's Avatar
Remove the negative (black) battery cable from the battery, and hold it against the positive (red) battery cable for 15 seconds.
As the negative battery cable is disconnected the battery is not in the circuit and does not cause a short, but if you are still cautious, remove both negative and positive battery cables and touch them together.
Old Nov 26, 2019 | 07:43 PM
King Charles's Avatar
Also pull fuse #15 from drivers side rear heel board & reinsert. This resets the drivers door control module, this worked for me when I had similar issues, mine turned out to be voltage related.
tomtomterrific
Jul 3, 2021 06:09 PM
Rideordie
May 25, 2018 05:38 PM
aamcobrian
May 24, 2018 07:59 PM
mattjw1
Aug 6, 2016 06:46 PM
jb91
Dec 7, 2008 09:04 AM
