windshield molding removal
Old Mar 27, 2018 | 12:23 PM
nitrojag's Avatar
Default windshield molding removal
anyone removed metal molding from around windshield to paint it? I don't want to damage it. any info will be greatly appreciated
Old Mar 27, 2018 | 12:53 PM
Daim's Avatar
Not hard, just wedged in. BUT afaik you can't refit it w/o taking the glass out...
Old Mar 27, 2018 | 01:28 PM
xjr2014_de's Avatar
Hi,
You can just lever it out. Take care that you don't bend it during removal. Otherwise this will lead to misfits during re-installation.
For windshield renewal the workshop manual recommends to fit the finisher before installation of the windshield. But you can re-fit it almost problem-free with the windshield in place with some patience, time and WD40/lube (if necessary).
Did that a couple of weeks ago with the front windshield's finisher using some plastic levers.
Will do the rear finishers in a couple of days.
Old Mar 27, 2018 | 01:32 PM
xjr2014_de's Avatar
By the way: Trim removal tools
Use kind of these plastic tools and you'll save the trim AND the rubber (and the windshield) from any damage and scratches.
Old Mar 27, 2018 | 02:08 PM
Sean B's Avatar
As others have said they come out and go in with the screen in-situe - washing up liquid and plastic trim tools make it relatively simple. I found a thin round pointed trim tool perfect for chasing the seal forward of the trim to slide in. The rear seal is no longer available from Jag. Be careful and slow.
Old Mar 28, 2018 | 09:20 AM
nitrojag's Avatar
Thanks All, I decided to tape and paint it,
Old Mar 28, 2018 | 11:47 PM
Daim's Avatar
Sure still is available... GXF9024AA
Old Apr 18, 2018 | 11:21 AM
nitrojag's Avatar
Doe's anyone know the color of the windshield trim molding on a 97 xk8 painted anthracite
i have checked with a dealer and he said they come already painted. thanks Robert
Old Apr 18, 2018 | 11:22 AM
nitrojag's Avatar
The color looks almost steel gray
car5car
Jul 7, 2014 05:47 AM
Tumbleweed
Jan 24, 2014 03:35 PM
mjlaris
Oct 6, 2011 03:44 AM
390HPTypeR
Feb 3, 2011 09:32 PM
390HPTypeR
May 14, 2010 09:52 PM
