Wobbly speedo needly, check engine n more
Old Dec 9, 2010 | 08:05 PM
Rique's Avatar
Default Wobbly speedo needly, check engine n more
I just finished replacing my steering rack. disk and brake pads and suspesion bushings. I also changed the oil, oil filter and fuel filter. After all was done I started engine. I get check engine, abs, traction control failure alerts. What is strange is the the speedo needle vibrates at around 10mph as if I was driving the car? Engine runs smooth as silk and steering works perfect. All sensors pluged in. I checked the fuses in the trunk non burnt. Any ideas will be greatly appreciated.
Old Dec 9, 2010 | 08:45 PM
test point's Avatar
I know that our respected professional, Steve11, does not believe in a 'hard reboot' but sometimes it does clear strange electronic issues.
I believe that the speedometer reads the transmission output shaft for the dash display through the TCM and ICM . . . and perhaps the BCM. Operates via FM.
That's as close as I can get to a helpful response.
Old Dec 9, 2010 | 11:09 PM
sparkenzap's Avatar
Rique:
You didn't forget to mention spray cleaning the engine compartment, did you?
BrentGardner
29
Dec 16, 2024 12:13 AM
philwarner
Dec 6, 2021 07:13 AM
Jimscriv
Nov 4, 2015 02:18 PM
looops
Aug 28, 2015 06:18 PM
divingmom
Aug 25, 2015 07:54 PM
