X308 4.0L gearbox
Old May 17, 2021 | 03:40 AM
Dw333's Avatar
Default X308 4.0L gearbox
I recently purchased a 4.0L with a broken gearbox, common issue broken drum inside (i dont totally understand) so also purchased another with a good gearbox so we have swapped them over and now have the same issue but it waa fine in the other car, it drives fine for a couple of mins then comes up gearbox fault and trys too pull away in a high gear (3rd ive been told), if you then turn it off and start up again, it clears for and works fine for a couple of mins again and does the same.
Any ideas please before i have a good 4.0L engine for sale and the rest is scrapped.
Many thanks
Old May 17, 2021 | 03:42 AM
Dw333's Avatar
Default Also
When plugged into a computar it shows fault code P1722 Stall Speed
Old May 17, 2021 | 08:03 AM
M. Stojanovic's Avatar
Otherwise, which gearbox control module (TCM) are you using, the original one or the one from the donor car? Check the ATF level and the selector cable adjustment. If those are ok, try swapping the control modules.
Old May 17, 2021 | 08:48 AM
motorcarman's Avatar
Oil level ok????
Old May 17, 2021 | 09:54 AM
Dw333's Avatar
I have tried both transmission ecu's and would either of you know how i can tell if the oil level is correct?
i got the gearbox warm and undone the bung, it just trickles out of the hole.
Thankyou
Old May 17, 2021 | 01:23 PM
The gearbox is checked COLD. (30 to 50 degrees Centigrade)
Start out at 20 degrees and try to catch the level at 30 but no more than 40 degrees. (tepid)
50 degrees is the MIN mark for the level.
enderle
I-Pace EV
Sep 22, 2020 03:40 PM
Chris Steineger
XK120 XK140 XK150
Jun 29, 2018 04:10 PM
jagtoes
Nov 14, 2017 09:59 AM
neil xk
Dec 11, 2008 06:54 PM
