x308 Differential Slow Leak
Old Oct 18, 2015 | 08:11 PM
Clayton Webb's Avatar
Default x308 Differential Slow Leak
Taking to a mechanic on Wednesday - just wondering how bad this looked? Don't see any drips on the garage floor.
Old Oct 18, 2015 | 08:20 PM
sparkenzap's Avatar
Well, since you will have the real story on Wednesday, what are you asking?
If you want re-assurement so you can sleep until then, I would say that if there is sufficient oil in the diff case, then this is nothing to worry about on a 15 year old car. If it is low, I would fill it and see how long before it leaked down again. Fixing the axle and pinion seals are going to cost several hundred dollars each, if that is needed. Most leak a little anyway.
Old Oct 18, 2015 | 08:32 PM
Thanks, pretty much just wanted to make sure it wasn't terrible. I can name a few of the moving parts on a car, so I rely on a mechanic to get everything done.
I figured it was good - but hoping it wasn't a reply like "OMG That bottom leak is the deally piston ring O cap - that's 4500 to replace!"
Anyways, off to the store for some wine...to help me sleep
Old Oct 18, 2015 | 10:40 PM
plums's Avatar
looks like it's coming from the breather and the two lower bolts on the cover.
Old Oct 19, 2015 | 08:34 AM
rocklandjag's Avatar
There is a breather port at the rear top of the differential (tricky to see). If it is clogged then seepage appears. The breather can be removed and cleaned. My diff stopped leaking after I cleaned mine. Don't let a mechanic tell you need new gaskets, seals, etc, just clean the breather
Old Oct 26, 2015 | 06:30 PM
Yep, mechanic looked at it, wasn't tightened all the way, oil looks good. Not a drop in the garage yet!
Old Oct 26, 2015 | 06:42 PM
King Charles's Avatar
Nice !
Old Oct 26, 2015 | 08:42 PM
sparkenzap's Avatar
Happy dreams!
Old Oct 26, 2015 | 10:56 PM
xjrjag's Avatar
Mine leaks...we have searched all over and couldnt pinpoint the exact location. Changed the breather valve at the top with a brand new one and changed the fluid...STILL has some seepage somewhere. Nothing that I am concerned with though.
Jag Princess 1
US Western
Dec 18, 2015 12:57 AM
Bucky83
Nov 1, 2015 02:28 PM
PolkNole
Oct 18, 2015 09:10 AM
LnrB
Oct 17, 2015 03:53 AM
Celticblood
Oct 16, 2015 10:14 PM
