X308 DIY Motor Mount / Engine Mount replacement
I need to replace both motor mounts / engine mounts and it's hard to find good info on how to do it.
There is one youtube video about the DIY process in which you lift up the engine using a normal jack lift, but it is not showing a lot of details:
Then there is a good explanation by "Sean B" in https://www.jaguarforums.com/forum/x...03/#post291573
Overall I'm a bit afraid to do this without more info - do you know of any other resources or repair manuals which cover the DIY method? Thank you
insomniac_driver
Apr 17, 2018 05:44 AM
