X308 DIY Motor Mount / Engine Mount replacement
Old Dec 1, 2021 | 11:25 AM
bfx308's Avatar
Post X308 DIY Motor Mount / Engine Mount replacement
I need to replace both motor mounts / engine mounts and it's hard to find good info on how to do it.
There is one youtube video about the DIY process in which you lift up the engine using a normal jack lift, but it is not showing a lot of details:
Then there is a good explanation by "Sean B" in https://www.jaguarforums.com/forum/x...03/#post291573
Overall I'm a bit afraid to do this without more info - do you know of any other resources or repair manuals which cover the DIY method? Thank you
12jagmark
May 20, 2020 11:22 AM
theusualsuspect
Apr 28, 2018 06:56 AM
insomniac_driver
Apr 17, 2018 05:44 AM
featherboxx
Jan 21, 2014 04:20 PM
plums
Nov 23, 2012 06:31 AM
