x308 reverse light issues.
Old Oct 12, 2018 | 02:59 PM
Colin Cross's Avatar
Default x308 reverse light issues.
Aloha all,
I've searched for a solution, but haven't been able to find one...
After purchasing a 1999 x308, I was informed that my reverse lights were not working... took a peek and there were no bulbs. Now that I've installed bulbs and replaced a few other, incorrect bulbs, often the reverse light will stay on after shifting to drive or park. Shifting back and forth will turn it off, but I really don't like tearing that cold transmission through the gears! Anyway, I'm now past due for safety inspection and need to get this sorted ASAP! Any help is appreciated!
-Colin
Old Oct 12, 2018 | 05:18 PM
Highhorse's Avatar
This you'll want to bookmark... JagRepair.com - Jaguar Repair Information Resource
You'll want to review this pdf from that site... http://www.jagrepair.com/images/Trai...des/201_SG.pdf
Here's a screen shot from that pdf for adjusting the Dual Linear Switch...
Old Oct 13, 2018 | 12:54 AM
Thank you for the link and PDF! I had thought about that, but all of the lights at the J gate are working fine. I'll mark the current position and give and adjustment. I'd be ecstatic if this was all it took!
Old Oct 13, 2018 | 04:54 PM
I don't think we're looking at the same setup. I have the ZF 5HP24 transmission, and looks more like pages 72-73. No dual linear switch is shown/seen there. Unfortunately, I can't seem to find anything in the previous section either.
Thanks again for the PDFs. Tons of good stuff there!
Old Oct 19, 2018 | 08:28 PM
Still looking for solutions if anyone has any ideas. I replaced the transmission rotary switch, which changed nothing. Can't keep driving this thing with expired inspection!
Old Oct 20, 2018 | 08:57 AM
Highhorse's Avatar
For your trans in that pdf, have you checked page 63 for the rotary switch? http://jagrepair.com/images/AutoRepa...ch%205HP24.pdf
Old Oct 25, 2018 | 07:54 PM
If you see above, I replaced the rotary switch and that made no difference. The new part looks cleaner, but that isn't helping. Been looking for burned wires, etc. around the gas tank, grommets, bends, etc.... Haven't been able to find anything. Next step is SLM, but I'd love some other suggestions before throwing $$ and parts at it...
Old Nov 14, 2018 | 10:54 PM
I finally received a used security and locking module from eBay. Swapped it out and the reverse lights work fine now.
Lude
May 25, 2024 03:51 PM
Titanos
Oct 25, 2023 02:54 PM
dannyray2803
Aug 28, 2019 01:16 PM
cdre
Jul 24, 2017 05:33 PM
xj8vdp
May 12, 2010 04:50 PM
