X308 XJR - Timing Chain
Old Jun 8, 2022 | 09:54 AM
595336100's Avatar
Exclamation X308 XJR - Timing Chain
Hello,
This car has a problem. I bought a set COMPLETE TIMING CHAIN ​​KIT but the craftsman tells me that it fits. See pictures. I have a question? Who's your experience on this issue.
Thanks in advance.
Old Jun 8, 2022 | 02:54 PM
motorcarman's Avatar
The chain sets sold (as yours kit is) are for the later 4.0 and 4.2 AJV8 engines. (engine S/N 0108130000 onward)
I always buy the original style primary guide blades from Jaguar (2 tensioner blades and 2 guide blades) for the earlier engines.
Some people use the wrong ones and just make them work.
I have not seen a 'correct' timing set for the early engines so a kit plus the correct primary parts are what I use.
Old Jun 9, 2022 | 05:04 AM
595336100's Avatar
Результаты перевода
star_borderThanks for answer. But I got a letter from Jaguar where it was written.
Old Jun 9, 2022 | 12:04 PM
595336100's Avatar
Old Jun 9, 2022 | 12:11 PM
595336100's Avatar
Can you tell me what you used for your car?
Old Jun 9, 2022 | 12:45 PM
The aluminum guides/blades are for the MORSE-STYLE 'silent running' chains used in the later engine.
I don't like using them in the early engines!!
Original style primary guides/blades for roller chain primaries.
Primary Guide NCA1998AB
Primary Tensioer Blade NCA2025AB
The Morse style guides are narrow because the Morse chains are narrow.
It's your car and free to use whatever you want.(my car/my choice)
Old Jun 9, 2022 | 08:47 PM
Highhorse's Avatar
Let's back up, ...where'd you buy it, ...what craftsman and what's your question? Yeah we see pics, but you fail to identify anything...I know what they are, but what's your issue sport. Your description is as clear as mud.
Old Jun 10, 2022 | 12:30 AM
M. Stojanovic's Avatar
Seems that the translation has caused the question to be unclear. Try again to explain the problem/doubts you are having regarding the timing parts you got.
Old Jun 10, 2022 | 03:02 AM
Welcome to the forums 595336100,
I've merged your two separate threads on this question so all the replies are together in the same place.
motorcarman has explained in posts #2 and #6 why the timing chain tensioners in the COMPLETE TIMING CHAIN ​​KIT you have purchased are different to the original ones on your XJR. It is a later design where the tensioners are longer and narrower and the chains are also narrower to match them. You can have this KIT fitted but he recommends using the original type.
I see you are in Tblisi, Georgia and options for obtaining Jaguar parts may be both limited and expensive.
Old Jun 10, 2022 | 09:34 AM
Highhorse's Avatar
My apologies, I thought your listing for Georgia was in the US. I had no idea you were in Eastern Europe.
Old Jun 10, 2022 | 12:52 PM
595336100's Avatar
Thank you .Everyone. Sorry for my English. Yes I am in georgia tbilisi. Here in the car, there is nothing. Here is the Jaguar Center, in everything I need
.3000 $. I need to order. So I started looking for an alternative.
Old Jun 10, 2022 | 01:15 PM
595336100's Avatar
I enjoy this car
[img]data:image/png;base64,iVBORw0KGgoAAAANSUhEUgAAABQAAAAUCAQAAAA ngNWGAAAA/0lEQVR4AYXNMSiEcRyA4cfmGHQbCZIipkuxnJgMStlMNmeyD2d wmc8+sZgxYJd9ErIZFHUyYYD7fkr6l4/rnvmtl7+KitrqV/fq2Y5eLY3Z9S48eRLe7BmVZ9qhTLhQ0algzZWQOVKSsCF8OjAn wbxDTWFDUhPK/jMr1H6HE/IqRky2DyvCefuwItwZzodVoYRiLqMkVCXrwpJ9twZ+sgfDYEFY l8wIWxZ9uFf7zkallxlJh4YrLGsKjZRx7VGHhLqwgFUN45DGdb 8MeXGpgB4ABZdeDcpZEY51A+hyLKz4S1W4MQWm3AibWtgWmk6d yISa1pSdyWTOlLXVp0+eL9D/ZPfBTNanAAAAAElFTkSuQmCC[/img]
Old Jun 10, 2022 | 03:02 PM
I have purchased the 'kits' that have all the parts but I just discard the primary guides/blades and use the metal tensioners (primary and secondary) because they are less expensive than individual from Jaguar or elsewhere.
I use the original chains if the engine has low mileage (I measure them against new to check for 'stretch') and if the chains don't look good, I discard and use the best chains I can find. The ones in the kit sometimes look 'flimsy' or substandard but some of them look good.
I like the original GUIDES/BLADES because they fit back as intended. (I provided part numbers in previous post #6)
A combination of the 'kit' and some OEM guides/blades is my preference for the repair.
The thin aluminum guides might work fine. I just don't like how narrow they are.
Old Jun 11, 2022 | 10:51 AM
595336100's Avatar
I will buy what you recommend. I will post news. thanks
Ken Cantor
Yesterday 12:59 PM
david f100
Non-Jaguar Vehicles
42
Jun 8, 2025 01:12 AM
ChristianRGR
May 24, 2022 12:25 PM
asjdhsajhdfj
Feb 14, 2022 02:40 PM
Swagguar
Aug 11, 2017 06:52 PM
