XJ Power Steering System Information
Hi
I created this PDF file from the JTIS21 section that has the power steering system with diagrams and components lists. Also gives descriptions and how it operates with its components:
XJ Range Steering System.pdf
See page 14 - Diagram and referenced part descriptions for servotronic control module (steering control module - LNE2100AA - servotronic rack pinion steering relay) located inside near lower panel on driver side, also servotronic valve forming part of the hydraulic control valve assembly.
See page 3:
The basic steering rack assembly is not serviceable. The following components are serviceable items:
Transfer pipework, Servotronic valve, Centralizing cap, Outer ball joint, Rack gaiter, Clips and fittings
Also per the PDU User Guide -Before changing a component, check fuse No. 12 (10A) in the left-hand heelboard fuse box.
Enjoy
Jim Lombardi
See page 3:
Enjoy
Jim Lombardi
Hi
Here is the Link to ZF Steering Gear Parts Catalog:
ZF Servotronic valve - Bing Images
Here is a one page PDF file I created from the ZF Jaguar XJ catalog page (to view the page properly you need to increase zoom in your PDF reader to 125%):
XJ Range Steering System 1.pdf
Page shows part numbers LH & RH drive, also for Sport model and non- Sport models.
Apparently the Sport has a different Steering rack than the other XJ models. Also the list price for the Sport model rack is much more expensive.
Jim Lombardi
Jim Lombardi
Dicque
Sep 19, 2015 12:53 PM
