Xj8 bmw transmission swap
Old May 22, 2018 | 08:13 AM
Dsucharda17's Avatar
Default Xj8 bmw transmission swap
I have a 98 4.0 jaguar xj8 got it from an online post the guy said it was a transmission leak fluid wan coming out now the car will only go into reverse everyone in a while and if it does engage into drive it will still so no clue what it may be but a local pick an pull location has a 99 740il which contains the 5hp24 which is the same in the jaguar would it be possible to do a swap or will the tcm have to be re wired or reprogrammed or had anyone did anything similar or may know the issue with the transmission
Old May 22, 2018 | 08:23 AM
I mean the car will stall once in drive if it engages other than that's it's as if it's in neutral
Old May 22, 2018 | 10:12 AM
Daim's Avatar
Nope it is not the same. The internals are but the rest isn't. The bolt pattern is different. The outlet for ATF is different.
Old May 22, 2018 | 10:14 AM
So any idea on what may be wrong with the current one in my jag possibly a fluid pump or torque converter?
Old May 22, 2018 | 11:01 AM
RJ237's Avatar
It's probably the classic A drum failure. Just put that into the search and you will have many threads to read.
n2audio
16
Apr 30, 2019 01:33 PM
Pristine97XK8Convertible
May 23, 2018 08:20 PM
Crushercurtis
Jan 11, 2016 09:55 PM
misham64
Oct 19, 2010 01:33 PM
