XJ8 Cut out and won't restart
Old Nov 11, 2012 | 11:42 AM
Trako's Avatar
Default XJ8 Cut out and won't restart
Well the jag was running perfectly, stopped at a junction and when I went to pull away it would not rev up, got round the corner and it cut out, tried to restart it fired a coulpe of times then would not fire at all so had to get recovered home. I have checked the fuel pump fuses and swopped the relays but I can't hear the pump running so I am thinking that the fuel pump has died any other suggestions would be more than welcome. Finally is the pump located inside or near to the tank.
Cheers Graham
Old Nov 11, 2012 | 04:23 PM
Sean B's Avatar
Hi welcome Graham - you should hear a high pitched whine in the boot when the ignition is switched on. A fast way to check fuel pump pressure is locate the schrader valve on the injection rail and press it while cranking, if it dribbles pump is over if it squirts all good...
Pump is in the tank, lazy people cut holes in their Jag to access the opening hatch at the top of the tank, a proper job is to pull it out enough to get to the top.
Trouble is you need to disconnect the two lines from the bottom of the tank, under the car and above the diff.
Old Nov 20, 2012 | 02:22 PM
Trako's Avatar
It was the fuel pump at fault, so fuel tank out and pump replaced so all good.
dsnyder586
Dec 29, 2024 07:39 PM
xjrjag
Oct 24, 2024 03:09 PM
99xk8guy
May 28, 2024 09:36 PM
Dickie_L_J_O
Sep 13, 2015 07:44 AM
tberg
Sep 7, 2015 07:32 AM
