XJ8 Door Latch and Cable Information Needed
Old Jan 26, 2013 | 09:50 AM
bluerdg's Avatar
Default XJ8 Door Latch and Cable Information Needed
My question for any that may have replaced a broken cable, does the crimp plug on the cable at the handle end have a flange on it to prevent it from pulling through the hole on the handle it slips into or is it cone shaped and just wedged in. About a year ago I had to perform a creative fix when it appeared the crimp plug had pulled through the hole on the handle. I've seen cables and handles available both separately and as a complete unit. I've got premium sound so a complete assembly would need to be the one with the speaker in the handle cup, while a cable alone would be cheaper it'd be useless if the handle is also broken. I can't find any pictures or descriptions that give a clear detail of the cable plug or the back of the handle. Any help is greatly appreciated, as I need to get something ordered so my wife doesn't have to keep rolling the window down to get out of the car.
Old Jan 26, 2013 | 02:18 PM
freeindeed's Avatar
Bluerdg,
I don't have an answer for you - I just wanted to say I'm dealing with the same problem right now (I think). I just bought my car second-hand, and when I test drove the car, they had the driver's door panel off fixing the cable. I picked it up "fixed," and two days later it broke again. So I'm going to do it myself this time, and I suspect I will find something like this to be the problem. I'm hoping I can find my own solution as opposed to buying the entire handle/cable assembly from Jag for...I think I heard $280+ dollars. We'll see. I don't have time to tear into it this weekend. It will probably be next weekend. I'll keep following this thread - let us know what you learn. I'll do the same if I'm first.
Chris
Old Jan 26, 2013 | 02:50 PM
pod184's Avatar
When I replaced mine, I think I got it from Coventry West.
To see a picture, zoom in on the picture on this Ebay auction (appears to be cone shaped):
Jaguar XJ8 Inner Door Handle Cable Rear Vanden Plas Free SHIP | eBay
Old Jan 27, 2013 | 10:54 AM
bluerdg's Avatar
Originally Posted by freeindeed
Bluerdg,
Chris
Sounds like you might have answered the question. When I first got into mine the fix looked simple enough, feed the cable into place and reinsert the crimp back into the hole on the back of the handle. Looking at the components there no question where things go. I figure there's a couple of things that could be happening (if crimp just wedges into hole) 1- the cable has stretched over time and is allowing the crimp to back out when the handle closes and slips out of place 2- Metal fatigue or wear on the handle is allowing the crimp to pull through the hole or (if not a wedge fit) there's a rim lip on the back end of the crimp that prevents it from pulling through the hole and metal fatigue and wear eventually cause it to fail. When the cable is in place it all fits together pretty tight so I can't tell by pulling cup on the passenger door. I've found new cables and salvage assemblies considerably cheaper than 280.
Old Jan 28, 2013 | 09:50 PM
Fyrplg's Avatar
Default door cable
I did a temporary fix as it had been done before and it lasted for a few weeks. I checked around and found that Welsh Industries had the new cable for aprox. $40 replaced about a year ago and still working fine .
also did the same on the 96 XJ6. Cable has a ferrel on the end that set in handle hardware.
Good luck.
Old Mar 14, 2019 | 04:19 PM
Diego Smola's Avatar
did you find the root cause, I broke 2 handles already....
Old Mar 14, 2019 | 04:59 PM
King Charles's Avatar
It's detailed in this thread ?! The door cable's end has a plastic collar that fails. The inexpensive replacement cables # GNC1101CBL are readily available on eBay & the like.
BrentGardner
29
Dec 16, 2024 12:13 AM
philwarner
Dec 6, 2021 07:13 AM
MarathonJohn
Sep 3, 2015 07:59 PM
91xjscoupe
Sep 1, 2015 12:01 PM
divingmom
Aug 25, 2015 07:54 PM
