XJ8 door lock
Old Apr 3, 2013 | 04:26 PM
Whitey's Avatar
Default XJ8 door lock
Hey all, I have a newly aquired 2001 XJ8 and I'm just realizing the rear passenger door will not lock using the door key or the lock button on the dash. When I manually set the lock it will unlock using both methods. Also, I'm presently working on sourcing the missing key fob and a spare key. Any insight is greatly appreciated.
Old Apr 3, 2013 | 06:16 PM
andrew lowe's Avatar
had this with my xjr, I took off the door trim and it was the boomerang shaped link that connects the button to the lock, there is a pivot at its centre that needed a little grease. a simple job that was completed inside an hour including cups of tea.
Old Apr 3, 2013 | 06:35 PM
Lear45's Avatar
You can find a Key Fob on Ebay for under $50. The key is $150 at a Jaguar dealership.
Not many other people can make one. You can program the remote yourself. Same with the built in Garage door openers. The forum has a thread on how to do that.
Old Apr 3, 2013 | 07:25 PM
Whitey's Avatar
Thank you both, have ordered the fob and programmed the garage door opener and will attempt to dissect the door tomorrow without damaging it. I'll do a wee bit more searching before I part with $150 for the key.
Old Apr 3, 2013 | 09:30 PM
Safi's Avatar
be careful not to snap the snowflake clips on the door car, they are replaceable but still still be cautious
Old Apr 4, 2013 | 06:06 AM
Whitey's Avatar
Thanks Safi, any hints how to avoid snapping the snowflakes would be much appreciated.
99xk8guy
Sep 29, 2025 10:51 PM
dsnyder586
Dec 29, 2024 07:39 PM
99xk8guy
May 28, 2024 09:36 PM
kevinl
Oct 31, 2019 06:15 PM
XJsc-guy
Nov 23, 2015 01:56 PM
