xj8 engine swap 3.2 to 4.0 SC
Old Jun 3, 2012 | 08:47 AM
dc4prez's Avatar
Default xj8 engine swap 3.2 to 4.0 SC
Hi, do any of you guys know if there is a parts list available for swapping out the engine and trans in a 1998 XJ8,
It has the original 3.2 litre engine, it's getting a bit tired at over 100,000 mile.
The ideal choice is a 4.0 supercharged
a few other questions - are the transmissions the same -
will I need a new wiring harness
What Control modules will I need
Help - has anyone done one of these conversions
Old Jun 3, 2012 | 12:28 PM
MoscowLeaper's Avatar
Transmissions are different. ZF on a NA cars, Mercedes 4spd on a SC.
Basically you'll need a harness from XJR and ALL of the modules, fuel tank with two fuel pumps and so on.
It'll be easier to swap for a 4.0 or 4.2 engine.
Old Jun 3, 2012 | 02:43 PM
Ipc838's Avatar
Actually, it's a Mercedes 722.6 5-speed from the E55/ S600.
I don't know how a 4.2 swap would be better, seeing as there was no
X308 with a 4.2 and it would be a big job.
Old Jun 4, 2012 | 07:12 AM
dc4prez's Avatar
Thank you - 4.0 litre it will be with trans
Cheers,
DC
Seems strange that Jag were owned by Ford (half of my car is left over Ford Parts) and they needed to buy Trannies from Merc, what does that tell you about the quality of Ford running gear
Old Jan 25, 2020 | 07:52 AM
Amrit Singh's Avatar
Default Did you do the engine swap in the end ? I’m in the same situation ow? Thanks for your
did you do the conversion in the end
Old Jan 25, 2020 | 10:31 AM
RJ237's Avatar
This thread is seven years old and I don't think the OP is around now. To make that swap you would need to do both engine and transmission, several modules and wiring harness. Much easier and probably much less expensive to buy a XJR
SteveSheldon
UK & Eire
505
Jul 14, 2016 04:48 AM
cissdm
May 3, 2016 06:02 AM
sogood
Sep 15, 2015 07:35 AM
bdboyle
Sep 4, 2015 06:16 AM
OkieTim
Sep 2, 2015 12:48 PM
