XJ8 Self Starter compression test
Old Mar 17, 2009 | 08:07 PM
JimT's Avatar
Default XJ8 Self Starter compression test
Can anyone tell me where to hook up the two wires of a remote starter, i'm going to do a compression check and I would just like to make sure that the connection are correct.
Jim
Old Mar 7, 2019 | 05:05 PM
stu46h's Avatar
Relieve the fuel pressure at the test port (use a test hose to direct the fuel into a container) and remove the fuel pump relay which is in the trunk. That will eliminate any fuel to the cylinders. Then you can crank the engine with the ignition key. Look for all compression readings to be within 25% of each other. Harbor Freight has a fuel pressure test kit for $20 and a compression test kit for $25.
Old Mar 8, 2019 | 10:41 AM
Jhartz's Avatar
Seriously, you couldn't wait nine more days so this thread would be exactly ten years old?
Old Mar 8, 2019 | 05:59 PM
Don B's Avatar
It wasn't exactly a thread, was it? More like a member who posted asking for help, but received no replies until stu46h came along with his helpful attitude. At least future readers will have the benefit of his reply.
Thanks, stu46h!
Cheers,
Don
Old Mar 8, 2019 | 08:35 PM
M. Stojanovic's Avatar
You need to access the back of the starter and disconnect the thinner of the wires from it (the thinner stud). Then move out the rubber boot from the thick cable connection (thick stud) and connect the remote starter to the two studs, thin and thick. Be careful not to cause a short, the thick stud has permanent +12V on it.
mls0036
Oct 17, 2015 10:03 AM
Guy-Pierre Boucher
Sep 16, 2015 05:55 PM
Shaggy9212
XJ40 ( XJ81 )
Sep 14, 2015 08:08 PM
corysansburn
Sep 10, 2015 06:15 AM
Doovoe
XJ40 ( XJ81 )
Sep 6, 2015 10:54 AM
