XJ8 side window gaskets unavailable?
Old Jun 6, 2023 | 09:40 AM
drfertig's Avatar
Default XJ8 side window gaskets unavailable?
My 2005 XJ8 VDP side CHROME TRIM (NOT window) gaskets (BOTH SIDES) are shot, too much SoCal sun I suppose. When it rains the back seat foot-well becomes a puddle - or pond! I'm told replacements are unavailable.... need I fabricate something? Any solutions?
Old Jun 6, 2023 | 10:28 AM
NBCat's Avatar
Have a look at SNG Barratt's website:
https://www.sngbarratt.com/English/#...assembly/30586
Old Jun 6, 2023 | 01:25 PM
RandyS's Avatar
Sad to say, there are not many ways to fix this problem (maintaining appearance) unless the crack(s)
are on the inside of the window gaskets, and even then the longevity is questionable. Some have used
thin layer of black silicone along the crack to help seal the leaks. Your least expensive option would be
to find a good used part from a salvage yard. You might even inquire from some of the members in the
forum who have parts cars who might sell you the gaskets for less.
Old Jun 6, 2023 | 05:43 PM
drfertig's Avatar
Thanks! I did contact them, Tony told me theyhad none, and after some research he said they ain't makin' 'em any more (the gaskets under the chrome trim that goes aboove both doors!)
I appreciate your response!
-Dave
Old Jun 6, 2023 | 05:48 PM
drfertig's Avatar
Thank you, indeed I have almost resignd myself to running a bead of something (silicon?) along/into the small gap on the top of the chome strip, I was told by a local mech that if I try to take it off I might not get it back unbent and in one piece.
-Dave
Old Jun 6, 2023 | 06:16 PM
xalty's Avatar
it’s not the gaskets you need to seal the passage under the trim on the pillar. it’s a straight shot to the rear footwell look at the tsb
Old Jun 7, 2023 | 09:05 AM
RandyS's Avatar
I guess you would be able to tell by using a hose and spray water on it to determine the
area where it is leaking. A serious leak like the one described should be easy to spot.
Old Jun 7, 2023 | 06:39 PM
944play's Avatar
OP might find more pertinent responses in the appropriate (X350) subforum.
Old Jun 9, 2023 | 06:10 PM
RandyS's Avatar
That's strange....I could have sworn when I read the first post it said 2003.
I also note that the first post was edited by the OP.
Sancho20
May 12, 2023 12:06 AM
jeffgoetz1
Apr 30, 2023 11:00 PM
User 070620
Jan 11, 2014 02:05 AM
Darel
Aug 13, 2012 05:05 AM
Spooky pantz
Jul 19, 2011 07:40 PM
