xj8 xk8
Old Aug 9, 2012 | 06:51 AM
blackwolf560's Avatar
Default xj8 xk8
do the xk8 transmission fit directly into the XJ8?
Found one for good price that was recently rebuilt aka probably have updated a-drum.
Old Aug 9, 2012 | 07:44 AM
xjay8's Avatar
I don't see why not...they are essentially the same drive train.
Although, I would be inclined to swap the gearbox ECM as i think it's all down to shift points within the box controlled by the ECM.
Old Aug 9, 2012 | 05:03 PM
Sean B's Avatar
Sorry to disagree with XJay, but I'd keep the original TCM just plug the connector in. The trans are the same, (4.0L) but I've never done the swap so can't tell you if the mountings are the same - maybe post it in the XK8 forum?
Old Aug 9, 2012 | 08:34 PM
found another for the xj8. it dont look as good but it has warrenty. cant wait and put off another day waiting for response there. time to get this car back on the road, hopefully no more delays and issues now.
Old Aug 10, 2012 | 08:59 PM
motorcarman's Avatar
ALL XJ/XK 4.0 NA ZF 5HP24 gearboxes will interchange!!!!!!!!!!!!!!!!!!!!!!!!!!!
The only part I have never tried to interchange between AJ26 and AJ27 are the rotary switches on the selector shaft on the right side of the gearbox. I use the one that was on the car originally.
The engines if kept AJ26 to AJ26 and AJ27 to AJ27, gearboxes (does not matter what year) will ALL interchange. You need to keep the original control modules in the car!!!!!!
bob gauff
mls0036
Oct 17, 2015 10:03 AM
Jdthomas
Sep 23, 2015 06:23 AM
jamiegogo
Sep 20, 2015 09:07 AM
Guy-Pierre Boucher
Sep 16, 2015 05:55 PM
wcourt3010
Sep 9, 2015 04:34 PM
