XJ8 to XK8 parts compatibility
Old Dec 9, 2014 | 08:18 PM
Beep777's Avatar
Default XJ8 to XK8 parts compatibility
I bought a 1999 XJ8 for parts. I have a 1997 XK8. I stripped the XJ8 and sent the body to the crusher. I want to with certainty (yes or no) if the following parts from the XJ8 will fit on the XK8:
-rotors and calipers
-ABS unit from under the hood
-airbags
B
Old Dec 10, 2014 | 06:02 AM
xjay8's Avatar
rotors and calipers
airbags
B
Practically all the mechanical parts and electrical parts are inter changeable.
The only differences are in some of the suspension linkages and exhausts
Old Dec 12, 2014 | 09:30 AM
Beep777's Avatar
That's what I was thinking. I could go in the garage and look at my XK8, but she is all tucked away for the winter and I was hoping not to bother her.
Anyone else with any input?
Brian
Old Dec 12, 2014 | 09:58 AM
Don B's Avatar
Hi Brian,
You should be able to get a very good idea about interchangeability by downloading and installing the Jaguar Electronic Parts Catalog from the download section.
https://www.jaguarforums.com/forum/x...uctions-48194/
Follow the instructions in the thread, especially the details posted by Jim Lombardi in post #75, and you will be able to look up part numbers for both cars on your own computer. That should at least give you an initial idea of which parts are compatible.
Cheers,
Don
Old Dec 13, 2014 | 02:59 PM
XKRacer's Avatar
I just stripped an XJR and knowing XKs like I do I also say yes all those parts will swap......
Front uprights are the same with the hubs, same as rear, even the seat modules work, I plugged one into an XK seat and everything worked..........
Old Jan 22, 2021 | 10:36 AM
Tex Mex's Avatar
Do you know if the radiator reservoir is the same for XJ8 and XK8?
Old Jan 22, 2021 | 12:03 PM
Don B's Avatar
It's very easy to answer questions like this at jaguarlandroverclassicparts.com. Just look up the part numbers for both models and see if they are the same.
Cheers,
Don
juliovega914
Nov 9, 2017 03:55 PM
pgguy
Canada
Jan 2, 2013 05:21 PM
Beep777
Dec 31, 2012 03:06 PM
JaguarXJ8
Apr 8, 2012 04:22 AM
