XJR Battery Issue
Old Sep 20, 2021 | 10:11 PM
PilotMajor's Avatar
Default XJR Battery Issue
Hi everyone,
New here, and I hope you all are keeping safe and sane.
After 4 months idle in the garage due to the endless Aussie lockdowns, my 1999 XJR battery has died. But it's also locked.
If I open the car with the key, will the alarm go off? Or will the alarm disable if I open with the key and get it to Ignition position 2 within the 15 secs.
Thanks in advance!
Chris
Old Sep 20, 2021 | 10:21 PM
PilotMajor's Avatar
Edit: as I can't see where to edit my post...
Sorry, all a bit new
Jag XJR 308, 5sp 4.0SC are the specs/
Old Sep 20, 2021 | 10:43 PM
xalty's Avatar
no just charge the battery and you’re good to go
Old Sep 21, 2021 | 10:48 AM
Vauxi's Avatar
Alarm will go on when battery is drained and you open any door or trunk or bonnet to give it juice. It will disarm rightaway if you push keyfob unlock button or as you described via turning key in to position 2.
richard134
May 2, 2014 01:48 PM
Ericbilt25
Oct 27, 2013 01:14 PM
gotmoss89
Jan 28, 2013 12:40 PM
gudcat
Jan 23, 2012 06:46 AM
camclean1
Feb 23, 2009 08:50 PM
