XJR cruise control failed
Old Sep 29, 2008 | 02:35 PM
Brutal's Avatar
Default RE: XJR cruise control failed
the common failures are throttle bodies and brake switches, need to have codes pulled to see what you have
Old Sep 29, 2008 | 07:35 PM
Markus's Avatar
Check your brake lights - while the "engine safe mode" light is on. If they don't work in that instance, replace the brake light switch. My XJR acted as you describe - all was well unless I had the cruise control operating, and then touched the brakes. Simple to replace the brake light switch (on underside of steering column) if that is the problem.
Cheers!
________
1999 XJR
Old Oct 13, 2008 | 06:48 PM
blkjag's Avatar
I had the same problem and found out I had a vacum leak at the Throttle Body. So trace your vacum line and crank it up and listen for air leak!
Old Oct 14, 2008 | 08:10 PM
oldmots's Avatar
It is possible that the left rear ABS sensor is acting up, this is the one that the system uses.
Forcedair1
Sep 8, 2025 01:57 PM
XJsc-guy
Sep 25, 2015 11:09 AM
Skeeter
Sep 17, 2015 08:15 PM
jaguarbill
Sep 5, 2015 11:43 AM
XFR_Gold
Sep 2, 2015 12:24 PM
