XJR eclectic fault
Old May 25, 2019 | 12:33 PM
Louis Nugus's Avatar
Default XJR eclectic fault
Hello I’m hoping someone may know what’s the issue..
my 1999 xjr has an ongoing issue, odd occasions when I unlock and prepare to start the car and engaging the key to first position all lights and everything will cut out as though the battery is dead. The only indication of power is the little red light flashing next to my gear stick. I can leave to car anywhere between 5 minutes to a day before it’ll kick back into power and all electrics will come back on. I’ve had my local jag garage look at it and they bought it was the relays or a fuse, which I’ve consequently had all replaced . Be it hot or cold weather had no difference on it
hoping someone else has had this issue as it ruining the joy I had driving it.
Many thanks,
Louis
Old May 25, 2019 | 01:25 PM
jackra_1's Avatar
XJ XJ8 / XJR ( X308 )1997 - 2003
You might have better luck in the above forum.
Old May 25, 2019 | 01:54 PM
Originally Posted by Louis Nugus
..... my 1999 xjr has an ongoing issue .....
Welcome to the forums Louis,
I've moved your question from X350 to X308 forum. This is the place to post technical questions about your model.
Old May 25, 2019 | 09:03 PM
M. Stojanovic's Avatar
...and engaging the key to first position all lights and everything will cut out as though the battery is dead.
I guess you mean key in the second position, i.e. ignition "on". When all the lights cut-out, keep the key in position and try wiggling the battery cables (the spare tyre removed). If this brings the power on, the problem is there; usually in the cable crimps. If this does not make any change, open the master fuses black box (to which the positive battery cable is connected) and try wiggling the fuses a bit. If this brings the power back, remove and clean the fuse terminals and seats ant tighten them back. Be careful not to overtighten the nuts as the bolt heads are sitting in plastic.
Old May 26, 2019 | 04:15 PM
Hi Graham thanks for the welcome and for moving my query to the appropriate place
Old May 26, 2019 | 04:20 PM
Came back to the car 24 hours later and started first time, when it happens next I’ll work through your suggestions, thanks v much 👍🏻
Cobrabp47
Apr 2, 2022 12:33 PM
alephzain
16
Mar 1, 2019 06:00 PM
donniefitz2
Feb 22, 2019 04:59 PM
tommo1471
Feb 15, 2019 10:08 AM
paulguitar
Feb 2, 2019 07:22 AM
