XJR Mercedes transmission behaviour.
Old Aug 12, 2013 | 07:54 PM
avt007's Avatar
Default XJR Mercedes transmission behaviour.
Hi guys,
Can some help clarify the way this transmission is supposed to work? I am very familiar with the ZF unit and how Sport mode behaves, but what about the Mercedes?
I've only had it on the road a couple days but haven't noticed much difference between Sport or nonsport modes. Is first gear used in Sport? Is reverse the same in either mode? Do the shift points get higher like the ZF?
Tonight I am going to test drive it again. At full throttle and Sport mode it was shifting at 4800-4900 rpm. I now realize I wasn't pressing hard enough to activate the kickdown switch. So on a quiet country road I'll try it again and see.
All input is welcome, thanks.
Old Aug 12, 2013 | 08:17 PM
dsnyder586's Avatar
It utilizes 1st gear and upshifts later- if you turn off traction control it will light up the wheels when you punch it from a stop..... That was one of the first things I tested.
Old Aug 12, 2013 | 08:18 PM
dsnyder586's Avatar
Also, check to make sure your accelerator cable is tight so you get 100% throttle...
Old Aug 12, 2013 | 10:59 PM
plums's Avatar
In sport+4 it also avoids torque converter lockup.
There is a adaptation procedure for the Merc transmission. Didn't make much, if any, difference when I did it.
Old Aug 13, 2013 | 07:57 AM
motorcarman's Avatar
There is a brief description of the W5A580 (722.6) in the XJ intro guide on page 50.
XJ Sedan 98MY Intro_jjm18151280.pdf
The gearbox is interesting because there are 2 reverse gears.
bob gauff
Old Aug 13, 2013 | 08:06 AM
smtguy's Avatar
2 reverse gears? Bob, could you explain that?
Thanks,
Old Aug 13, 2013 | 11:56 AM
avt007's Avatar
Hi Bob,
The document you listed isn't linked, thanks.
Old Aug 13, 2013 | 08:52 PM
avt007's Avatar
I suspect the kick down switch is not working. At full throttle it shifts at 5000 RPM in sport mode.
Old Aug 13, 2013 | 09:56 PM
The XJ sedan MY98 intro .pdf is a large file (around 8mb) So I don't think it will upload to the posts. It should be somewhere in the large file download area.
It says that the file size limit is 9.57mb but I have failed to upload any more than about a 3mb file.(I just tried and it FAILED)
The W5A580 has 2 reverse gears, The HIGH reverse gear is engaged in the NORMAL mode and the LOW gear in the SPORT mode. (I have never tried to switch between them 'on-the-fly' to see if the difference can be noticed)
Page 57 of the document describes the shiftpoint calculations as well as basic operation and LIMP MODE.
The document is called....
bob gauff
Old Aug 13, 2013 | 11:46 PM
avt007's Avatar
OK thanks Bob, I'll try to find it. I removed the kickdown switch, took it apart and cleaned it, and now she pulls to redline. And wow is she fast!
aholbro1
Dec 29, 2024 06:46 PM
Rlover
Mar 30, 2016 10:04 PM
XJsc-guy
Sep 25, 2015 11:09 AM
SouthernGypsy
Sep 23, 2015 04:06 AM
Jaguar Forums Editor
Jaguar Press release
Sep 5, 2015 10:08 AM
