XJR with Nag1 not going into overdrive
I've been refurbishing an XJR I purchased as a project. It always seemed like there was a dronening noise on the freeway but I thought it might be tires or something. Anyway, I replaced the transmission fluid and have been really paying more attention to the shifts lately. The car is shifting perfectly but I don't think it's going into overdrive. When I'm doing 70 and I put the Jay gate into 4 it doesn't change. It's at about 2100RPM's when doing 70. Any thoughts?
Great math. Thank you. I'll try and find a flat roadway to test again. Nothing changes though when I go into 4th on the J gate. Maybe it doesn't kick out of 5th until you put your foot into.
If you're counting shifts and thinking you're in 4th, be aware that when the trans is in normal (aka non-sport) mode, it starts in second gear.
Do any other gears on the manual side of the gate work? Like if you start in 2nd, does it holds second gear or does it upshift? The left side of the gate is electronically controlled, while the PRND side is a physical cable control...I'm wondering if your dual linear switch may be faulty or need a cleaning.
Jhartz (09-30-2023)
Update. I took the car out and there is an issue with the J gate as mentioned. When shifted into 4th it doesn't illuminate red. There may be some coke or Red Bull in there. I haven't really messed around with it too much in sport mode. I decided to bury it tonight with it switched on and the car really took off. Scary fast. It always seems to hold 3rd or 4th in normal mode resulting in lackluster acceleration. Thanks again for all the input.
I bought a dipstick off eBay and measured what came out and put that amount back. I used Maxlife fluid. I've got another gallon to run through, Just drain and fill at this point. Don't have to drop the pan again. I think it was the original fluid, It was pretty dark. Also did the connector housing.
Which is that it's compatable with the Nag1 transmission, which is good enough for me.
GerryXJR
02-18-2013 08:42 AM
