xjr propshaft bolt loose???
Old Jan 25, 2010 | 10:30 AM
xjr4life's Avatar
Default xjr propshaft bolt loose???
hi everyone can anyone pls tell me why on of the bolts would be loose what causes it?
once tightened is it ok? or is it something really really bad?
regards
Old Jan 25, 2010 | 10:35 AM
xjr4life's Avatar
sorry i meant why one of the bolts^^^^
Old Jan 25, 2010 | 01:26 PM
QuadManiac's Avatar
I'd suggest simply re-tightening then checking occasionally, until you're satisfied that it's going to stay tight.
As to cause, perhaps it was miss-tightened at some previous maintenance point... or better minds here may have more informed suggestions.
Old Jan 26, 2010 | 12:29 PM
xjr4life's Avatar
thanks buddy jus hope thats all it was a mis tightened like you stated, and not a fault will drive for a week and see if it gets loose again
regards
Old Jan 26, 2010 | 12:37 PM
ken@britishparts.com's Avatar
Also, check the rubber flex couplers for cracking or aging.
aholbro1
Dec 29, 2024 06:46 PM
GordoCatCar
Jan 2, 2017 01:10 PM
Dickie_L_J_O
Sep 13, 2015 07:44 AM
sadepol01
Sep 11, 2015 05:26 AM
JagLove86
Sep 6, 2015 10:36 PM
