XJR smoke on start up
Old Aug 1, 2016 | 09:37 AM
JTsmks's Avatar
Default XJR smoke on start up
car in question is a 02 XJR-100 with 47k on the odo. Took a 25 mile drive last night to the airport to pickup the Mrs and when I started it in the parking garage a BIG billow of smoke came out of the exhaust (grayish in appearance) this AM upon start it did the same thing. Any ideas? I really don't need this aggravation in my life right now, seems like when it rains it pours!
Old Aug 1, 2016 | 09:49 AM
Highhorse's Avatar
What happens after the zika mosquito fogging, does it run normal afterward? ...does it run sluggish, vibrate or chug? ...does the smoke continue or clears off? ...have you checked to see if your oil is over filled?
Old Aug 1, 2016 | 09:56 AM
JTsmks's Avatar
No oil added since last change over a month ago, runs fine after initial "fog", performance seems fine, no smoke on kick down at speed or heavy acceleration from a standing start.
I hesitated to buy this particular car as I knew it had been thrashed a bit, it's had the heads off and regasketed plus an arp stud kit.
Old Aug 1, 2016 | 10:25 AM
JTsmks's Avatar
I just pulled the stick outside the store and its reading about 1/4" above the "max" line, I haven't put any in since my last change AND its never done what it did last night or this AM before. After I left the store it didn't do it upon start up.
Old Aug 1, 2016 | 11:24 AM
plums's Avatar
Quarter inch won't do it.
I run mine at a full inch above max.
Old Aug 1, 2016 | 11:29 AM
Mark SF's Avatar
That is to prevent the problem where the front bearing spins, is it?
Old Aug 1, 2016 | 11:31 AM
plums's Avatar
silverstone spec
i just don't have the silverstone dipstick
Old Aug 1, 2016 | 11:37 AM
JTsmks's Avatar
Yeah, I figured as much or it would be doing it since the last change
Old Aug 1, 2016 | 12:42 PM
Mark SF's Avatar
Originally Posted by plums
silverstone spec
I do admire brevity, but your posts tend to read like a telegram, where you're being charged by the letter.
I literally have no idea what you're referring to.
Old Aug 1, 2016 | 01:17 PM
80sRule's Avatar
Basically, specced to hold one more quart.
I think the logic may have been the same as Aston Martin shortening the dipstick on the DB9. The logic being make the dipstick indicate in a way to tell you to put more oil in than the original factory spec to prevent damage from oil starvation under certain driving conditions.
Old Aug 1, 2016 | 02:05 PM
JTsmks's Avatar
A little amplifying info, when I pulled the s/c about a month ago there was oil sitting in the elbow connections to the air charge coolers. Which seemed rather odd.
Old Aug 1, 2016 | 03:49 PM
plums's Avatar
well i've never heard anything about a front bearing spinning either.
so it was a riposte to that and no more than that.
Old Aug 1, 2016 | 04:06 PM
Highhorse's Avatar
Have you checked your breather pipe coming off the valve cover?
Old Aug 1, 2016 | 04:18 PM
JTsmks's Avatar
Yeah, it's the first thing I checked, dry inside. Hasn't done it since. I'm at work now and it'll have sat in the lot for 5 hours when I leave. Fingers crossed it was a fluke thing that straightened itself out......I'm never that lucky.
Old Aug 1, 2016 | 04:43 PM
Doug Dooren's Avatar
My wife's '99 XJR developed smoking on initial cold startup a few years back - not a big cloud but definitely not normal for a very low mileage car - probably 20k mi. It turned out to be leaking injectors - apparently the high pressure would slowly bleed fuel into the cylinders overnight and there would be a puff of smoke on startup. I believe the dealer ran the engine on injector cleaner (not certain what they used), and the car has been fine since. Might be worth a try if the problem persists. Good luck.
Old Aug 1, 2016 | 05:15 PM
Mark SF's Avatar
The original problem that the increased oil capacity was supposed to fix, was oil starvation while cornering hard. The most common symptom of that oil starvation was spinning the front main bearing.
DJS
May 23, 2017 04:37 PM
studentper
Mar 3, 2017 06:24 PM
Jul 28, 2014 07:18 PM
tonysilverstone
May 9, 2006 11:50 PM
Jan 8, 2006 11:44 PM
