XJR Timing Alignment
Old Sep 23, 2012 | 04:21 PM
TN8Shooter's Avatar
Default XJR Timing Alignment
In a rush to complete the timing chain job, I stupidly pulled the primary chain off of the passenger side without installing the camshaft locking plate.
Chains are off and this is what I have so far.
1. Flexplate lined up to inset plug
2. All cams flat spots in correct position
3. #1 Cylinder TDC
The passenger side primary chain has slack in it on the top of the chain. Does anyone know if I can just rotate the sprocket to take up the slack?
Old Sep 23, 2012 | 08:32 PM
motorcarman's Avatar
You cannot have the crank flexplate lined up for the lock tool AND the #1 @ TDC!!!!!
bob gauff
Old Sep 24, 2012 | 11:04 AM
Jim702343's Avatar
I mistakenly pulled out the tensioners without lining everything up, I pulled the cams out then lined up the crank and put the cams back in so the flats were aligned. It took a little more time but it was better than bending a valve trying to turn it when I had no idea if things were lined up or not.
The car runs perfectly!!!
Old Sep 24, 2012 | 07:56 PM
TN8Shooter's Avatar
It's actually slightly after TDC I belive.
Sprayall
May 30, 2021 08:13 AM
tberg
Sep 7, 2015 07:32 AM
Sprayall
Sep 3, 2015 07:49 PM
XFR_Gold
Sep 2, 2015 12:24 PM
