XJR/X308 Differential vs XKR/X100 Differential
Old Apr 14, 2021 | 05:36 AM
benfbrown's Avatar
Default XJR/X308 Differential vs XKR/X100 Differential
Well, I have the dreaded differential whine on my 2003 XJR with 71k miles. After doing some reading, I thought there was a good bet that it would be the output shaft bearings so I sourced a used differential from an XK with 48k miles for less than what it would cost to get one bearing, lol. I knew that the output shafts were the same so I swapped the ones from the XK with mine. No change in the noise whatsoever.
So, since the noise is definitely coming from the differential, it has to be internal. I am lucky enough to have a big shop near me that specializes in differentials and they have done 14hu's before. So, I can take the differential to them for a refresh if I supply the parts. The internal bearings, crush sleeve, seal, etc. are all on order.
To save me some time, it occurred to me that I could give them the XK differential for the rebuild while I spend the hours it will take to remove mine, lol. HOWEVER, I seem to recall in another thread that there are differences between the two differentials but I can't remember the specifics.
I can clearly see that the pinion flanges are different but my question is whether the internals the same or different?
Thanks in advance!
Ben
Old Apr 14, 2021 | 08:41 AM
motorcarman's Avatar
Pinion flanges are different. The ratio needs to be considered as well.
Old Apr 14, 2021 | 09:26 AM
benfbrown's Avatar
Thanks, Bob!
shl1980
Sep 2, 2013 12:26 AM
johnleavitt
Jan 30, 2013 10:37 AM
azeteg
Sep 28, 2012 02:14 PM
user 2029223
Sep 20, 2011 10:48 PM
Horice
Sep 16, 2010 11:24 PM
