XJ40 ( XJ81 ) 1986 - 1994
1994 xj6 wont start
Old Nov 8, 2012 | 04:23 AM
Glacebeatz's Avatar
Default 1994 xj6 wont start
Hey guys ive got a 1994 xj6 and i disconnected the battery because the alarm went off. Now the car wont start. I dont hear anything. The dashboard lights come on and the security system light stays lit but the car dosnt start. Is this a security issue or what? i really need help on this one. Heard this is kind of a common issue. Anyone else having this going on?
Old Nov 8, 2012 | 05:00 AM
Check the replies to your Intro in New Member Area - Intro a MUST - Jaguar Forums - Jaguar Enthusiasts Forum section.
Old Nov 8, 2012 | 05:04 AM
OK, first things first, you are NEW, so welcome.
Your '94 XJ6 is toooooo new for this area, as it is either an XJ40, or a very early X300.
To identify. Does it have spark plug leads (XJ40), or does it have 6 coils under a plastic cover with "Jaguar" embossed in it (X300).
Once this is identified, one of the Moderators will hopefully move this to the correct area to maximise answers specific to your model.
Either way it sounds like the security system is having a hissy.
I have NO hands on with that, as mine does what it should at all times, but "sometimes" disconnecting the battery again, ensuring ALL the doors are closed, and reconnection has the desired effect.
Old Nov 8, 2012 | 07:39 AM
Glacebeatz,
Now you've confirmed it's an XJ40, I've moved your thread from XJ6 Series I, II & III section to XJ40 section.
The guys here should be able to advise on the non-start.
Old Nov 8, 2012 | 08:52 AM
MidwestJag's Avatar
Glacebeatz:
Welcome to the forum. I would first check the Inertia Switch under the driver's side footwell behind the fusebox. If that is tripped, the car will not start. There is a little knob on the top that will pop up if tripped. Push it back down and see what happens.
Also, if you plan to keep this car any length of time, you should get a Haynes manual at a minimum. It will at least get you pointed in the right directions for issues such as these. And believe me, this is not going to be a maintenance-free car; but it is a fun and rewarding one.
Cheers,
Scott
Old Nov 8, 2012 | 11:49 PM
Glacebeatz's Avatar
Default Thanks lol more questions
lol Ok and where exactly is that switch that i should push down......The fusebox on mine is in the center console?
Old Nov 12, 2012 | 04:25 PM
AlphaDogX24's Avatar
Glace, just press the Security Button on your key holder And that security light should cut off up there, and it should start right up. i always had to press that button EveryTime i reconnect the battery. Hope that helps
Old Nov 13, 2012 | 04:11 PM
MidwestJag's Avatar
There are two fuse boxes on either side of the car on the outer sides of the footwells. Under the drivers side, behind the fusebox, is the inertia switch. If it is tripped, the car will not crank. It's probably not your problem, but is certainly is the first thing to check.
...And, get yourself a Haynes manual.
Scott
Old Nov 14, 2012 | 07:46 AM
Glacebeatz's Avatar
Default Jag
Thanks you guys. Ill see if your suggestions work. Hopefully they do. I appreciate it. Do you guys take your cars to the dealership?....i was told not to
Old Nov 14, 2012 | 07:15 PM
NO, NO, NO.
The dealers down here want NOTHING to do with any Jaguar that is more than 5 years out of factory warranty.
If I cant fix it, it aint broke.
Old Nov 14, 2012 | 09:18 PM
Glacebeatz's Avatar
Default suckss
If I cant fix it, it aint broke? that didnt even make sense. But nothing worked you guys lol...
Old Nov 15, 2012 | 01:52 PM
"it aint broke" Lol, Heyyy Hahaha, So i take it the Security light didn't go off?
Old Nov 17, 2012 | 10:32 PM
Glacebeatz's Avatar
Default solution
Nope, not at all. I took it to the dealership. Just found out its the computer module. cost about $900. So i guess thatll take care of it. Just cant wait till i can drive it on the road again.
Chet Ramnarain (bozzner)
Sep 3, 2015 12:21 PM
Harry Dredge
Sep 3, 2015 03:04 AM
d a
Sep 3, 2015 02:34 AM
Harry Dredge
Sep 2, 2015 02:26 PM
