XJ40 ( XJ81 ) 1986 - 1994
1988 XJ6 Climate Control not working
Old Jan 2, 2012 | 09:48 PM
Yaoi-Wiccan's Avatar
Default 1988 XJ6 Climate Control not working
My 1988 xj6 Climate control will not work at all. No matter what button I push the fans do not turn on. The only thing that works is the backlight and the light on the rear window heater. I checked both fuses and they seem good. Any ideas what the problem is?
Old Jan 3, 2012 | 03:30 AM
Cadillac's Avatar
Does A/C compressor kick in ? Your best bet is you need freon to charge the system . I hope it's that as simple as a recharching freon
Otherwise you may need a new compressor
Old Jan 3, 2012 | 08:39 AM
No it does not. Nor does the heater or blowers. Nothing seems to turn on
Old Jan 3, 2012 | 08:44 AM
motorcarman's Avatar
The fault is a common one and you need a new micro-switch or a replacement panel (salvage)
Here is a very old TSB for the repair procedure.
I have done this repair DOZENS of times and I keep a micro-switch and #2-56 screws in stock for the few that I actual see anymore.
I actually did this repair several months ago and I found my 'stash' of switches and screws.
bob gauff
Old Jan 4, 2012 | 06:32 PM
mrtalkradio's Avatar
Great info Bob
ClassiXtype
Oct 22, 2023 05:29 AM
johnnie ryall
Oct 19, 2015 09:44 PM
97xj6lucy
Sep 3, 2015 07:44 AM
GreyXK
Aug 31, 2015 05:15 PM
smokin_hobo
Aug 29, 2015 12:13 AM
