XJ40 ( XJ81 ) 1986 - 1994
1990 4.0 no injector power and no pulse
Old Jun 20, 2011 | 08:37 PM
5clinks's Avatar
Question 1990 4.0 no injector power and no pulse
So I have a 1990 xj it is getting spark and fuel to the fuel rail but it is not getting through the injectors I do not know a whole lot about Jag but I am ready to learn. it seems to be on the electrical side of thing it is not getting + power to the injectors nor is it getting a - pulse. I have checked the white wire off the coil it seems fine as do the earth connections near the water neck. any ideals would be appreciated.... oh yah this is Us left hand drive car SAJHY1743LC5XXXXX
Old Jun 21, 2011 | 11:04 PM
5clinks's Avatar
Have I found a problem that stumps all? anyone? any ideals will work for now just something to start looking at will be good HELP ME
Old Jun 22, 2011 | 04:53 AM
I'll move you on over to the XJ40 section one of the guys will point you right about checking injectors and maybe fuel pressure.
Old Jun 22, 2011 | 11:35 AM
Trick Freestones's Avatar
Default 1990 VDP ECU to fuel injector schematic
Hi 5clinks and welcome to the Forum.
Tell us more about your car. Was it running and just quit? Did you buy it in a non-running condition?
Did you use a NOID tester to determine there is no f.i. signal?
Do you have a Haynes? If not you should get one from eBay or an Internet bookstore. In our case it is worth the money.
1st suggestions:
1. Check to see if your inertia switch has been tripped. I can see this happening if the car has been towed, but ...
2. Did you post you are getting spark at the plugs? If so your amplifier is working.
3. Get an assistant and place them at the fuel pump which is under the car and in front of the tank. Have him or her hold their hand on the pump and tell them to feel for the vibration of the pump when running. Turn the ignition key to on (but don't crank). The pump should come on and then quit. Now turn the key to crank and if the engine management ECU receives a crank or run signal, the pump should come back on.
4. The following is a schematic of the wiring between the engine management ECU and the fuel injectors for a 1990 VDP.
  • Wire KB is pink with black tracer and KU is pink with blue tracer.
  • LIS6 and LIS8 are harness connectors you will have to trace back from the fuel injectors to find
  • LI58 is a 25-way AMP socket (black) located driver footwell/ engine management ECU
Check all wires for continuity and connections for tightness and good electrical conductivity.
Good Hunting and keep us informed.
Attached Thumbnails 1990 4.0 no injector power and no pulse-90_vdp_ecu_to_fi.jpg
Old Jun 22, 2011 | 10:18 PM
5clinks's Avatar
Hello Trick Freestones
Thank you for the reply. It was not running when I bought it. I used a led and filament test light not a noid. I do not have a book this is a left hand drive car the only computer type box on the driver foot well I found is the passive restraint box. the other siege the right there is a lot of boxes (computers)
hoodun
Aug 10, 2021 10:32 AM
Ozzy_UK
General Tech Help
Jan 14, 2016 02:52 PM
Roger95
Sep 25, 2015 02:05 PM
Ozzy_UK
Sep 24, 2015 08:44 PM
Bcrary3
Sep 11, 2015 10:36 AM
