XJ40 ( XJ81 ) 1986 - 1994
1992 XJ6 Heater issue
Old Jan 3, 2020 | 03:37 PM
Zachary Howard's Avatar
Default 1992 XJ6 Heater issue
Good afternoon, my 1992 Jaguar XJ6 has the following issues: when I turn defrost on, barely any air blows out oh, and when I switch it to the heater blower, there is a very loud clicking sound. No air comes out of the vents. Could it be a blower motor? Has anyone else seen this issue? Thank you.
Old Jan 3, 2020 | 05:05 PM
Welcome to the forums Zachary,
I've moved your question from General Tech Help to XJ40 forum for advice from members with the same model.
Old Jan 3, 2020 | 07:57 PM
motorcarman's Avatar
Please read through the forum post here
https://www.jaguarforums.com/forum/x...o-heat-226197/
Old Jan 3, 2020 | 11:00 PM
Lawrence's Avatar
Sometimes one blower will stop working (there are two) and very little air will seem to be generated, if any, as the good one will blow into the bad one rather than out of the vents. You can check which side has failed by pulling the blower fuses on each footwell fuse box.
If that is the case, one isn't working, post back and maybe we can help you diagnose the problem.
Larry
Flat Top
Dec 11, 2018 03:00 AM
elantoys
Jan 24, 2018 12:51 PM
jdm2004
Jan 25, 2017 12:20 PM
G_Stype
Jan 12, 2015 03:44 AM
paulmcgouran
Feb 4, 2013 02:53 PM
