XJ40 ( XJ81 ) 1986 - 1994
1994 Vanden Plas Engine?
Old Jan 8, 2010 | 10:53 AM
pablackcat's Avatar
Default 1994 Vanden Plas Engine?
I need to replace the motor in my 1994 Vanden Plas - she valiantly gave her life at 90mph but got me to work. Will a donor motor from a 1991 Vanden Plas (VIN SAJK Y174 1MC646251) fit my 1994 (VIN SAJK X174 3RC691038)?
Old Jan 8, 2010 | 11:20 AM
ken@britishparts.com's Avatar
The 94 is a unique engine. The head configuration is different.
Old Jan 10, 2010 | 02:38 PM
pablackcat's Avatar
I see the radiator is different with the 1994 having the electric fans as opposed to the belt drive. Also noted that the oil filler cap is located beside the valve cover as opposed to on the valve cover. Apart from that, If I purchase an entire 1991 VDP can I retrofit the motor (ie change out the radiator as well)? What about the rest of the drive train - as I was also thinking about changing out the rear axle (from the 1991) and replacing the coil springs and shocks. Maybe the whole thing from radiator, motor, tranny, and shafts back to the rear axle. Is this something that can be done or is it just a completely different motor/drivetrain. Thanks.
Old Jan 11, 2010 | 03:40 AM
Hi I am just an enthusiast like yourself but I do have almost one of each of the cars you are talking about. 92XJ40 (driver) 94XJ40 (spares). When I look at the two side by side the only difference I can see is the fan setup. (which if I get bored over the summer I might make the change to the later setup).
The rest looks to be just cosmetic, interior trim differences (colours).
When I check your two Vin numbers, I come up with 6cyl 4L cars in both cases.
You can confirm for yourself here:
http://www.autocalculator.org/Free-V...&vin3=2PA26883
This is for Ken, I know that the engine underwent some revision in 95 for the X300 with the AJ16 motor, but I can't find any difference between the 91 and 94 engines AJ6 or drive trains, unless it was an early 4L TWR XJR.
Please will you point me in the right direction. Thanks in advance, Richard
Old Jan 11, 2010 | 10:03 PM
pablackcat's Avatar
Thanks!!! I'm working on it . . . I appreciate your response!
Old Jan 12, 2010 | 10:07 AM
With the different valve cover setup, you get a different breather system. I guess you could swap if you included swapping all that stuff. By the time you invest that kind of time and effort, it would be less expensive just to buy a 94 model.
D.K
Dec 10, 2023 02:05 AM
cissdm
May 3, 2016 06:02 AM
scottatl
Sep 4, 2015 08:08 PM
d a
Sep 3, 2015 02:34 AM
OkieTim
Sep 2, 2015 12:48 PM
