XJ40 ( XJ81 ) 1986 - 1994
88XJ40 Coolant Sensor Removal?
Old May 15, 2012 | 01:25 PM
88xj6's Avatar
Default 88XJ40 Coolant Sensor Removal?
I don't seem to be getting smarter here. 1988 XJ6. May have bad coolant sensor. I detached the coolant reservoir, took off the large knurled ring and now can't see how to remove the sensor from the tank. Does it have o-rings and you just pull it straight out? Everything is plastic so I did not want to ream on it until I find out how it is supposed to come out of the hole.
This is the one which enters the tank on its rearward end.
Old May 15, 2012 | 01:26 PM
88xj6's Avatar
Ooops, I should have said coolant level sensor.
Old May 15, 2012 | 09:24 PM
motorcarman's Avatar
The level sensor just pulls out.
The hinged plastic part needs to be installed so that the end drops down once the part is reinstalled. Note the orientation when the part is removed.
bob gauff
Old May 16, 2012 | 12:59 PM
88xj6's Avatar
The sensor did not readily pull out. I will wait until the replacement arrives before getting more aggressive with it.
I did jump the contacts on the wiring to the dash, as suggested by postings here, and, sure enough, the low coolant message disappears, suggesting that the sensor itself is kaput.
Old May 22, 2012 | 09:33 AM
88xj6's Avatar
Sure enough, with a little persuasion the sensor pulls straight out. Installed new one and yahoo, "coolant level low" warning is now gone. One tiny victory.
Jandreu
Jan 23, 2017 10:58 AM
KarimPA
Sep 12, 2015 08:15 AM
jimmiejag
Sep 9, 2015 02:56 PM
Xkr x100
Sep 6, 2015 08:50 AM
KarimPA
Sep 3, 2015 07:32 PM
