XJ40 ( XJ81 ) 1986 - 1994
91 xj40 growling at 40mph then ceases
Old Apr 19, 2020 | 12:08 PM
wsv32451's Avatar
Default 91 xj40 growling at 40mph then ceases
91 xj40 growling at 40mph then ceases at about 45 then again on deceleration at about 40 again then ceases by 35.
Can't tell location at all just unique loud hum or growl.
Got to get it on lift.
Anybody experience this cause if you've had it you'll know.
Take care.
Old Apr 19, 2020 | 12:15 PM
Lawrence's Avatar
Check your wheel bearings
Larry
Old Apr 19, 2020 | 02:20 PM
wsv32451's Avatar
91.xj40 growling could be OR MOST LIKELY. wheel bearing noise?
That would be awesome.
That'll blow me away if it' is.
THANK YOU .
will get right on it and advise.
Fingers crossed bigtime.
Old Apr 21, 2020 | 02:48 PM
Don B's Avatar
Another thing to check is the differential output shafts where the axles meet the diff. Any oil leaks from the side of the diff usually indicate failure of the output shaft bearings, which is very common on Jaguars since the rear axle serves as the upper suspension control arm, which puts the diff output bearings under more stress than on most vehicles.
Cheers,
Don
Old Apr 22, 2020 | 08:48 AM
wsv32451's Avatar
Don
appreciate this info. Very much.
Will check and update accordingly.
Had on lift and didn't locate any obvious issue that'd do this but will look again with your suggestion. It's a hider that's for sure.
No growling on rack.
Wheels are all good.Small power steering pump leakage.but all dry otherwise...surprisingly.
Take care.
Thanks again.
Old Apr 24, 2020 | 03:39 PM
wsv32451's Avatar
Cheers,
Don
seems good everywhere , no leaks near any rotating units. No slack,no noise.
At rear of trans when rocking driveshaft(wheels also) just a small click but again no excess slop anywhere .
I'll figure it out if I have to wait for it to explode
great forum.
will advise on locating and repair solution
Old Apr 27, 2020 | 04:25 PM
impster's Avatar
Try using a mechanics stethoscope and with the rear wheels rotating, listen to the hubs for wheel bearing noise or the differential for output shaft bearings. My car was noisy as heck while driving but the source wasn't obvious when on the lift with the wheels rotating. The stethoscope quickly pinpointed the source: a wheel bearing. And because I was already part way there, also did the output shaft bearings at the same time.
Old Apr 27, 2020 | 05:26 PM
wsv32451's Avatar
Sure will try that.
anything possible .
Got me puzzled.
David's Car Blog
XJ40 ( XJ81 )
May 6, 2015 05:33 PM
Steve W
XJ40 ( XJ81 )
Jul 16, 2012 10:58 PM
oliviermv
XJ40 ( XJ81 )
Jul 13, 2012 10:36 PM
Translator
XJ40 ( XJ81 )
Aug 17, 2009 10:38 AM
xj40kid
XJ40 ( XJ81 )
Jul 10, 2008 03:20 PM
